ᐅ Which tools make assembling Ikea PLATSA easier?
Created on: 12 Aug 2020 08:27
sesu10
sesu10
12 Aug 2020 08:27
Hello everyone, I am currently planning to assemble an Ikea Platsa wardrobe and wondering which tools can really make the assembly easier. Besides the included hex key and hammer that Ikea provides, there must be other useful tools that make the work more comfortable or faster. Which tools – both manual and power tools – have you used when assembling PLATSA and would you recommend? Are there any special aids or tricks that should not be overlooked when connecting the modules or attaching the back panels and doors? I look forward to your experiences and tips!
Lotizar
12 Aug 2020 09:14
There are several tools that can significantly simplify the assembly of the Ikea PLATSA. Basic tools include Phillips screwdrivers (PH2) and a reliable cordless drill with the appropriate bits, as many fasteners are screwed in.
In addition, the following are recommended:
- A rubber mallet for gentle fitting without damage.
- A protractor or a spirit level to align the modules accurately.
- Clamps to hold parts in place while screwing.
The included hex keys are often too small and uncomfortable to use, so investing in a quality set of hex keys (Allen wrenches) is worthwhile. A utility knife is useful for trimming the back panels if needed. Patience is also important when screwing the many connections, as careful work pays off.
Dwight49
12 Aug 2020 10:38
Basically, I can only agree with Lotizar. Additionally, I would like to mention that a cordless screwdriver with torque control is highly recommended to avoid over-tightening screws or damaging the material.
Furthermore, a magnetic screwdriver or magnetic bits make handling easier, as the small screws can easily be lost if they slip. A soft surface such as a blanket or mat also effectively protects the fronts during assembly on the floor.
Especially with the PLATSA series, it is important to work precisely and carefully, as the modules often need to be aligned exactly with hinges and tracks.
Guyju
12 Aug 2020 14:56
Here is a brief step-by-step overview of the tools I used when assembling PLATSA and how they helped:
1. Cordless drill (with hex bit): For all screws, especially the connectors and back panel screws. Saves a lot of time and effort.
2. Rubber mallet: Useful for fitting the connectors together without scratches or damage.
3. Phillips screwdriver PH2: For fine adjustments on hinges and small screws.
4. Spirit level: To ensure everything is perfectly level—especially important for wall mounting.
5. Utility knife: To trim back panels or laminate as needed.
A small tip: If the PLATSA unit has multiple modules, it’s helpful to have an extra person assist with holding and aligning. Often the back panels are installed first and need to fit precisely—this is where careful work with the tools listed above really pays off.
sesu10 schrieb:
Which tools—both manual and power—have you used and would recommend for assembling PLATSA?
The combination of a cordless drill plus good hand tools makes assembly much more efficient.
Demetrius
13 Aug 2020 08:31
I can fully understand that assembling PLATSA can initially feel a bit intimidating, especially if you don’t build furniture regularly. What helped me a lot was taking my time beforehand to carefully read the instructions – this often makes choosing the right tools much clearer.
At first, I sometimes had minor issues aligning the panels correctly because I was working without extra clamps. So, I arranged some clamps and involved a second person, which made the process much more relaxed.
I would also recommend using a rubber mallet; feeling the right impact and protecting the surface provides a better sense of control and preserves the finish. When installing the hinges, I was grateful for the small Phillips screwdriver bit and cordless drill for precise work. Don’t worry, even if it seems complicated – step by step, it’s definitely doable!
Garthre
13 Aug 2020 12:02
In addition to the tools already mentioned, I also recommend a small, flexible LED lamp or headlamp in case the lighting at the assembly site is not ideal. This provides better visibility, especially when working with small screws and precise assembly.
A quality cordless screwdriver and hex key sets are essential because the tools provided often have issues, such as worn edges or lack of comfort.
For back panels, I worked carefully with a sharp utility knife to make minor adjustments, particularly if the floor was not completely level. PLATSA modules, in particular, require exact positioning to avoid problems opening the doors later.
