ᐅ Which tools are helpful for assembling Ikea Hemnes furniture?
Created on: 10 Jan 2018 09:18
Knutren
Hello everyone, a few days ago I bought an Ikea Hemnes wardrobe and now I am faced with the task of assembling it. Since Ikea tools are often quite basic and I want to work as efficiently and stably as possible, I am interested in which tools you recommend for assembling Hemnes furniture.
I am especially curious whether it makes sense to use tools in addition to the included hex key, such as other screwdrivers, cordless drills, or similar; what type of hammer or rubber mallet might be helpful; and whether specialized clamps, squares, or clamps have proven useful.
It would also be good to know if you have any specific tricks for certain steps that are easier with the right tools.
So, which tools really help you when assembling Ikea Hemnes furniture, and what tips can make the process easier?
reoWilhelm11 Jan 2018 08:14What helped me a lot in my last Hemnes project was a simple trick: always keep a rubber mallet within reach to gently tap wooden dowels or connectors into place. You can’t rely on force alone; the parts need to be joined carefully.
A cordless drill is a must, of course. But if some screws don’t fit perfectly, having a good Phillips bit for fine adjustments is worth it.
Also, lightly marking with a pencil before screwing helps prevent any shifting.
KarTristan11 Jan 2018 10:47The tip about using a spirit level is very important, especially when assembling shelves or cabinets, to ensure nothing is crooked.
Additionally, a small wrench can be helpful for nuts when using self-adhesive nuts in the back panel, as some can be difficult to tighten securely by hand.
The quality of the tools makes a big difference here; cheap hex keys can wear out quickly.
To summarize:
- A cordless screwdriver with fine adjustment
- Rubber mallet
- Phillips screwdriver
- High-quality hex keys
These are the basic tools. For precise work, I also recommend a small pair of pliers or combination pliers to adjust wooden dowels if necessary.
Assembling furniture like Hemnes does not require specialty tools, but using this set allows you to work faster and with fewer mistakes.
- Rubber mallet
