ᐅ Which tools are helpful for assembling Ikea Hemnes furniture?
Created on: 10 Jan 2018 09:18
Knutren
Knutren
10 Jan 2018 09:18
Hello everyone, a few days ago I bought an Ikea Hemnes wardrobe and now I am faced with the task of assembling it. Since Ikea tools are often quite basic and I want to work as efficiently and stably as possible, I am interested in which tools you recommend for assembling Hemnes furniture.
I am especially curious whether it makes sense to use tools in addition to the included hex key, such as other screwdrivers, cordless drills, or similar; what type of hammer or rubber mallet might be helpful; and whether specialized clamps, squares, or clamps have proven useful.
It would also be good to know if you have any specific tricks for certain steps that are easier with the right tools.
So, which tools really help you when assembling Ikea Hemnes furniture, and what tips can make the process easier?
Samir
10 Jan 2018 11:07
For assembling Ikea Hemnes furniture, I recommend the following tools:
- A cordless drill with adjustable torque to quickly and securely fasten the supplied screws without damaging the wood.
- A Phillips screwdriver for detailed work and to replace the cordless drill in tight spaces.
- A rubber mallet, as it allows you to gently join wooden parts without damaging the material.
- A spirit level to align the furniture piece at the end.
The included Allen wrench is usually sufficient for the screws, but a high-quality Allen wrench or bit can make the work easier since Ikea tools are often not very durable.
Clamps can be helpful if you need to hold several parts in place while screwing, but they are not essential.
SINEL
10 Jan 2018 11:45
Cordless screwdrivers and rubber mallets are the most important tools.
It is better to replace hex keys with high-quality Allen wrenches.
Avoid using a pressure hammer, as it can leave dents in the wood.
mifra
10 Jan 2018 14:39
I agree with this and would like to add: Pay attention to a cordless drill with a fine torque setting so that screws are not driven in too deeply, which could otherwise cause the material to swell or damage the thread.
I also recommend sorting and preparing all screws and fittings before the actual assembly. This makes installation easier and helps avoid unnecessary searching during the work.
Basic hand tools, such as a small set of flathead and Phillips screwdrivers, are useful in case the cordless drill cannot reach certain areas or for making fine adjustments.
Garry
10 Jan 2018 15:26
Knutren schrieb:
I am particularly interested in whether it makes sense to use other screwdrivers, cordless drills, or similar tools in addition to the provided Allen key
Yes, that definitely makes sense. The supplied tools are often minimal, designed to keep costs low.
A cordless drill significantly speeds up assembly and prevents hand fatigue. I also recommend using a magnetic bit holder to avoid dropping screws – it saves time and frustration.
Regarding a hammer: a rubber mallet is preferable because the wood in Hemnes furniture is relatively soft and can dent easily. The rubber mallet allows you to position parts gently.
Finally, a small folding square can help to align individual elements precisely at right angles before screwing them together.
KINMIN4
10 Jan 2018 18:03
A cordless screwdriver with large and small bits.
A rubber mallet instead of a metal hammer.
A Phillips screwdriver as a backup.
That’s all you need to easily assemble Hemnes furniture.
