ᐅ Which tools do I need to properly adjust IKEA BESTA doors?
Created on: 27 Oct 2019 08:23
U
USJON
U
USJON
27 Oct 2019 08:23
I am planning to properly align the doors of my IKEA Besta cabinet, as they currently do not close completely flush and some hang slightly crooked. My question is: which tools are best suited to adjust the doors on IKEA Besta furniture precisely and permanently? I am particularly interested in whether, in addition to the usual Allen wrenches and screwdrivers, any special equipment is needed to fine-tune the doors perfectly. Are there tools that make the adjustment process easier or more accurate, especially when several doors need to be aligned simultaneously? I would appreciate a detailed overview of the necessary tools and advice on the procedure.
RYANLA42
27 Oct 2019 09:47
To adjust the IKEA BESTA doors, you mainly need a Torx screwdriver or bit (usually T20) for the screws on the hinges, as well as a thin flathead or Phillips screwdriver for fine-tuning. A small hex key (4 mm) can also be useful if any adjustments are needed on the rails. You won’t need any other tools.
Tarlo
27 Oct 2019 12:15
The adjustment screws on IKEA BESTA doors are usually Torx T20, so having a corresponding Torx bit or screwdriver is essential. Additionally, I recommend getting familiar with the three adjustment axes on the hinge (height, depth, lateral), each requiring different screws.
Besides screwdrivers, a small angle gauge or a bevel gauge is useful if you want to align the doors at right angles to each other.
If you are adjusting multiple doors at the same time, a spirit level or a laser level makes it easier to check the alignment with walls and ceiling.
Basically, you need:
- Torx T20 screwdriver/bit
- Small Phillips or flathead screwdriver
- Spirit level or laser level
- Bevel gauge or small angle gauge
Make sure to use reliable tools to avoid damaging the screws.
Rashadmeo
27 Oct 2019 18:56
Hey, great topic! I adjusted my BESTA doors entirely using just a good Torx screwdriver and a small spirit level – it really made a big difference! 😄 My tip: be patient, the screws can be very sensitive sometimes!
And very important: not just the tools, but good lighting and a steady hand are invaluable. If you look at the doors from multiple angles, you’ll immediately notice any minor mistakes.
Give it a try, you’ll see the result is worth it! 👍
Liduta
28 Oct 2019 07:38
Hello, I’d like to pick up on this topic and provide a brief step-by-step guide:
1. Preparing the tools:
- Torx T20 screwdriver (recommended: good grip for precise turning)
- Small Phillips or flathead screwdriver for fine adjustments
- Optional: small, handy spirit level or preferably a laser level
- A narrow spatula or thin plastic strip as a spacer can be helpful
2. Adjusting the doors:
- Start with the height adjustment (vertical screws on the hinge). This moves the door up or down.
- Then adjust the lateral position to align the door flush with the cabinet frame.
- Finally, adjust the depth so that the door sits evenly and opens/closes smoothly.
3. Checking:
- Use the spirit level or a straight edge (e.g. ruler) to check the alignment of the doors relative to each other.
- Make sure the doors sit evenly against the cabinet frame and the gap is consistent everywhere.
Common mistakes:
- Over-tightening can damage screws or hinges.
- Turning the adjustment screws too quickly or too far.
Summary: Mainly a Torx T20, a small flathead screwdriver, a level/laser level, and some patience are all you need. This is how you can optimally adjust your IKEA BESTA doors.
