ᐅ Which tools do I need for the fine adjustment of Ikea BESTA doors?
Created on: 23 Oct 2024 08:37
Nanizar
Nanizar
23 Oct 2024 08:37
I recently bought an IKEA BESTÅ sideboard and noticed that the doors don’t close properly and hang slightly unevenly. My goal is to be able to adjust the doors precisely so that they are perfectly aligned and close cleanly.
My question to you is: What tools or aids are needed for fine-tuning the BESTÅ doors? I would like to know if I should have specific screwdrivers, hinge adjustment tools, or any other practical tools ready.
I’m also interested in whether these tools differ from the common tools people usually have at home (like cordless drills, hex keys, etc.) or if there is something special to consider.
I look forward to your tips, as I want to approach this carefully and without unnecessary trial and error.
KAULIS
23 Oct 2024 09:12
A precise answer to your question: For fine-tuning the IKEA BESTÅ doors, the following tools are generally useful:
- A Phillips screwdriver (PH2), as most BESTÅ hinges use these screws.
- A small Allen key (often 3 or 4 mm), in case you want to adjust the hinges using these screws.
- For some models, a flathead screwdriver can be helpful for adjusting the angles or shifting the door panel.
There are no tools specifically designed for BESTÅ. Common DIY tools are usually sufficient. It is important to make adjustments on the hinge screws,
where the side screws allow depth adjustment, the vertical screws control height, and the front screws enable lateral alignment.
If you want to organize your tools properly, I recommend keeping a small set of various screwdrivers and Allen keys ready. A spirit level or a small level app on your smartphone can also help when checking alignment.
PeoDaniel
23 Oct 2024 10:05
Hello Nanizar,
I can totally understand your situation! Especially with the BESTÅ doors, it’s really important to use the right tools and techniques because small mistakes can quickly become bigger problems. I’d like to add a few points:
- As KAULIS already mentioned, Phillips screwdrivers (PH2) are essential.
- Additionally, a small Allen key (usually 3 mm (1/8 inch)) may be needed – IKEA sometimes uses different types of screws on the fittings.
- A nylon hammer or a small rubber mallet can be helpful if you want to gently adjust the doors without damaging the surface.
- Don’t forget that if the doors squeak or stick, using some silicone spray or furniture wax on the hinges can be handy.
I also recommend making adjustments step by step and checking frequently whether the alignment improves, so nothing gets overtightened or damaged by accident. If you’re unsure about your DIY skills, just take it slow and work in small steps.
If you want a more detailed explanation of how the different screws work and the direction you should turn them, I’d be happy to explain that as well.
Nabla64
23 Oct 2024 11:29
here is a brief guide on how to fine-tune the IKEA BESTÅ doors using the correct tools.
First of all: The BESTÅ hinges are so-called "clip-on" hinges, which usually offer three adjustment options:
- Lateral adjustment: Allows you to move the door left or right to regulate the gap between the doors or the cabinet.
- Height adjustment: To move the door vertically, so it hangs evenly.
- Depth adjustment: To adjust the door inward or outward, meaning closer to or further from the cabinet.
For these adjustments, you typically need a PH2 crosshead screwdriver.
The tools:
- Important: a good quality, not too small PH2 crosshead screwdriver with the right blade size to avoid damaging the screws.
- Optional: a small hex key (Allen wrench), in case your model uses a screw with an internal hex socket.
- A small spirit level or smartphone app to check the alignment.
The process:
1. Open the doors and locate the hinge screws.
2. Use the crosshead screwdriver to slightly adjust the lateral setting until the gaps look even.
3. Adjust the height using the corresponding screw.
4. Finally, fine-tune the depth so the door sits flush and does not stick.
Common mistakes:
- Over-tightening the screws.
- Adjusting the wrong screw.
If you like, I can later provide photos or a more detailed description of the screw positions (text only, of course).
blapau
24 Oct 2024 07:43
Just a quick tip from me: For fine adjustments, I strongly recommend using the original IKEA screws and not replacing them with screws from other accessories, as the stress points on the hinges are specifically designed.
I also suggest a steady hand and not applying too much force when adjusting, as the plastic or metal parts in the hinge can break or become worn out.
For a more professional approach, consider getting a fine Phillips screwdriver with a good grip. The advantage is that you have better control over the torque.
This helps avoid stripped screw heads, which can make later adjustments much more difficult.
In short: Tools:
- Precise PH2 screwdriver
- Optional 3-4 mm (0.12-0.16 inches) Allen wrench
- Spirit level
And above all, patience.
Kinbu
24 Oct 2024 19:17
PeoDaniel schrieb:
I also recommend making all adjustments step by step and repeatedly checking whether the settings have improved, to avoid over-tightening or damaging anything by accident.
Absolutely correct! I would like to add that with BESTÅ doors, it sometimes helps to check if the door is properly seated on the hinge. Especially during assembly, the magnets or metal clips may not always engage correctly.
So, the tool isn’t everything. Still, you should definitely have a good Phillips screwdriver ready— IKEAs use only standard screws there.
Sometimes I also use tweezers or small pliers when small parts or plastic pieces in the hinges need to be aligned.
If you are mounting the doors from scratch, it’s worth initially tightening all screws only lightly, making all adjustments, and then finally tightening everything securely.
In short: For fine-tuning, you’ll need
- Phillips screwdriver (PH2, preferably with a good grip and flexible blade)
- Optional Allen key (3–4 mm)
- Small spirit level
and a bit of patience.
