ᐅ Which tools do I need for a simple replacement of IKEA BESTA hinges?
Created on: 25 Dec 2023 14:37
SeblaHello everyone, I am planning to replace some broken hinges on my IKEA Besta furniture soon, and I’m wondering which tools are ideal for this job.
Specifically, I want to know which simple hand tools will really make the repair easier—especially since I’ve never done this before and don’t have a large set of tools.
Are there any special screwdrivers I should use, or will regular Phillips or flathead screwdrivers be enough? Do I maybe need a cordless drill or other tools like pliers or something similar?
Also, regarding the removal of the old hinges and the installation of the new ones: are there tips to avoid unnecessary hassle?
In short: based on your experience, which tools are necessary and sufficient to carry out a simple replacement of IKEA Besta hinges without requiring too much technical equipment or professional gear? Thanks in advance for your recommendations!
Sebla schrieb:
My main concern is which simple hand tools actually make the repair easierI would first ask what exactly you mean by ‘simple.’ If you want to tackle the job without much experience or a full toolbox, the speed and time required can vary a lot, so durability is something to consider as well.
For me, a medium-sized Phillips screwdriver that feels comfortable in the hand is standard. IKEA hinges usually use Torx or Phillips screws, so definitely avoid using a flathead screwdriver or the wrong bit — that will damage the screws and make any replacements much harder.
A cordless drill with adjustable torque can be helpful in principle, but it’s not absolutely necessary as long as the screws turn easily.
Also, a small pair of pliers or needle-nose pliers can be useful if there are clips or small metal parts that need to be carefully removed.
My advice: don’t just focus on the tools, but also on finding a good working position and having patience. Replacement hinge models can vary, so it’s helpful to compare the old hinges before buying or installing new ones.
To address the question of which tools are really useful for the simple replacement of IKEA BESTA hinges, I have put together a small guide that can provide good orientation, especially for beginners:
- Phillips screwdriver (ideal size PH2): Most IKEA BESTA hinges are fastened with Phillips screws. A PH2 is the most common size and fits the screws.
- Optional cordless drill with torque control: This helps prevent screws from being over-tightened or damaged but is by no means essential.
- Needle-nose pliers or multipurpose pliers: Useful for removing or adjusting small clips or retaining springs on the hinges.
- Small stabilizing pad or cloth: To protect the surface during screwing.
Common mistakes I often see:
- Using a screwdriver that is too small or too large, which rounds off the screw heads.
- Screwing too quickly, which often leads to poor alignment of the hinge.
My recommendation is to carefully inspect the old hinges and identify the screws and their type before replacement. For the exchange, the furniture parts should be placed as stably as possible and be easily accessible.
Summary: A good Phillips screwdriver (PH2) is usually sufficient, complemented by pliers for small tasks. A cordless drill can save time but is not absolutely necessary.
To finalize the topic of tools for the simple replacement of IKEA BESTA hinges, here is a comprehensive overview that also covers small details:
1. Screwdriver:
- Mainly Phillips screws (PH2) are used. Using a good, non-worn screwdriver is crucial. Cheap or worn screwdrivers cause cam-out and make the work more difficult.
- A screwdriver with an ergonomic handle ensures good torque transfer.
2. Cordless drill/driver:
- Not essential, but highly recommended with adjustable torque to minimize the risk of over-tightening screws.
- Make sure the bits are compatible with the screws, e.g., PH2 bits.
3. Pliers:
- Needle-nose pliers help with aligning clips, small springs, or removing cotter pins (if present).
- A small flat-nose pliers can also be useful.
4. Optional:
- A small flathead screwdriver can help with gently prying off clips on some models.
- A protective cloth or mat prevents scratches on the furniture surface.
Procedure:
- Fully loosen the hinge screws before moving anything on the furniture piece.
- When installing new hinges, pay attention to precise positioning. Sometimes there are adjustment screws that need to be properly set to ensure the doors close cleanly.
Regarding the question of whether a screwdriver alone is sufficient: In my experience, it is almost always enough; a cordless drill/driver speeds up the process, especially if you want to replace multiple hinges.
If the old hinges are badly damaged or rusty, it is advisable to have a spray can of rust remover ready.
One more question for you: Which exact hinge types do you want to replace? Is there a model number? There are differences between the cabinet side and the door side that can influence the tools needed and the disassembly process.
1. Screwdriver:
3. Pliers:
4. Optional:
Procedure:
