ᐅ Which tools do I need to repair Ikea Brimnes furniture?
Created on: 17 Apr 2019 13:07
goditra
Hello everyone, I plan to repair my Ikea Brimnes wardrobe, which is slightly unstable in some areas and sometimes doesn’t close properly. My specific question is: which tools should I have on hand to carry out a precise and safe repair? I want to avoid damaging any parts unnecessarily or assembling anything incorrectly. If there are any special aids or technical accessories that could make the process easier, I would also like to know about them. Thanks in advance for your tips and experiences.
danial60
18 Apr 2019 11:13
For a thorough approach, I recommend the following systematic procedure with tools:
- Start with a general-purpose Phillips screwdriver, preferably with interchangeable heads for flexibility.
- Additionally, good hex keys (Allen wrenches) are necessary, as some internal connections are secured with these, often size 4 mm (0.16 inches).
- A cordless drill/driver with precise torque control can both simplify assembly and prevent damage.
- Also, a small rubber mallet is useful to apply controlled force without damaging materials.
- A small set of precision pliers is helpful for fine adjustments of hinges or for pulling out metal sleeves.
- Finally, use a spirit level and a measuring tape to check alignment.
Do you have a specific issue with a certain type of screw or discolored/loosened connections? That might further affect your choice of tools.
goditra
19 Apr 2019 08:46
Muso4 schrieb:
I find it interesting how often it’s assumed that Phillips screwdrivers are the standard – in fact, the tools provided with Ikea furniture, especially with Brimnes, are particularly minimalistic
Thanks for the tip, that matches my concern exactly; the included tools are often too small and not very durable. I have a small cordless drill with a torque limiter. Do you think it would be safe enough to avoid damaging the screws in the cabinet? Or should I just work entirely manually? My main goal is to improve stability without damaging the fittings.
JAMESONB41
19 Apr 2019 09:12
With a cordless screwdriver that has a torque limiter, you are well equipped. Choose a low setting and work slowly. It is more difficult to control the force manually, especially when working with MDF.
Declan55
20 Apr 2019 07:39
Great that you already have so many plans! If the cabinet at the lower corner is wobbly, it’s often because the dowels are no longer properly fixed or the connectors have loosened. My tip: use a bit of wood glue on the dowel joints to increase stability. As for tools, you’ll only need a screwdriver, a cordless drill, and a small hammer for gentle tapping. And don’t worry about the repair – with the right tools, even beginners can handle it! Good luck!
