ᐅ Which tools do I need to repair Ikea Brimnes furniture?
Created on: 17 Apr 2019 13:07
goditra
goditra
17 Apr 2019 13:07
Hello everyone, I plan to repair my Ikea Brimnes wardrobe, which is slightly unstable in some areas and sometimes doesn’t close properly. My specific question is: which tools should I have on hand to carry out a precise and safe repair? I want to avoid damaging any parts unnecessarily or assembling anything incorrectly. If there are any special aids or technical accessories that could make the process easier, I would also like to know about them. Thanks in advance for your tips and experiences.
taotis53
17 Apr 2019 14:23
For repairing an Ikea Brimnes cabinet, you should first prepare some basic tools: - A Phillips screwdriver (preferably with an ergonomic handle) - A hex key, usually size 4 or 5 - A hammer for minor adjustments or tapping in dowels - Optionally, pliers for gripping or fine-tuning the connectors Usually, this is sufficient since Ikea furniture uses standardized fasteners. Be careful not to overtighten screws to avoid damaging the material.
Johnathon
17 Apr 2019 15:05
I would like to add that when repairing Brimnes cabinets, so-called cam lock fasteners are often used. For their safe handling, besides an appropriate Phillips screwdriver, a small hex key is often necessary, as some screws can have slightly different sizes. Additionally, I recommend having a small set of screwdrivers of various sizes on hand, since the included tools are sometimes a bit awkward to use. It is also important to have a tape measure and possibly a square if you want to check the alignment of the cabinet doors. Have you already identified specific spots where the cabinet is loose or where there are problems closing? That could help narrow down the choice of tools.
goditra
17 Apr 2019 15:37
Johnathon schrieb:
Have you already identified specific spots where it wobbles or there are problems closing?
Yes, mostly the cabinet wobbles at the lower left corner, and one of the cabinet doors does not close flush but hangs slightly inward. The hinges do not seem loose; it might rather be an issue with the paneling or anchoring. Therefore, I want to make sure I have the right tools with me, because I don’t want to just tighten screws without checking the overall situation.
Mathew
17 Apr 2019 16:21
Based on the described issues, I recommend the following: - A medium-sized Phillips screwdriver for tightening screws on hinges and joints - A Torx screwdriver in case your model uses Torx screws (rare with Brimnes, but better to check) - A precision screwdriver set for small screws, especially on the hinges - A small hammer and, if needed, a rubber mallet for gently adjusting the joints - An adjustable wrench or pliers if nuts are present A small spirit level is particularly helpful for checking the alignment of the doors. Avoid using excessive force, as IKEA furniture is made from MDF and can be damaged.
Muso4
18 Apr 2019 09:08
I find it interesting how often Phillips screwdrivers are assumed to be the standard—especially with Ikea furniture like Brimnes, where the provided tools are very minimalistic. Many underestimate how useful a cordless screwdriver with adjustable torque can be. Of course, it’s not a typical tool to have in a basic toolbox, but it is much more precise and efficient. This might be a controversial point, but if you have the option and are assembling more than just one item, it’s worth it. This way, you avoid over-tightening and incorrect positioning. Naturally, for someone who prefers to keep things minimal, a good screwdriver is sufficient.
