ᐅ Which tools do I need for repairs on IKEA HEMNES furniture?
Created on: 29 May 2023 16:12
tinoben
tinoben
29 May 2023 16:12
Hello everyone, I am currently planning some minor repairs on my IKEA Hemnes wardrobe and would like to get your advice: Which tools should I definitely have on hand to properly carry out typical repairs such as tightening screws, replacing fittings, or gluing cracked wood surfaces? I already have a cordless drill, but I’m unsure if I need any additional specialized tools or if standard tools will be sufficient. I’m especially interested in tips on tools that are particularly useful or recommended for HEMNES furniture. Thanks in advance for your help!
Dilen
29 May 2023 18:46
Hello tinoben, your question is very clearly formulated, I like that! For repairs on IKEA HEMNES furniture, I recommend a set of basic tools complemented by a few specific aids. Generally, these are the most important tools to fix common damages:
- Phillips and flathead screwdrivers in various sizes (a small Torx driver can sometimes be useful, as IKEA occasionally uses such screws)
- Cordless drill with adjustable torque control to avoid over-tightening screws
- Hammer or rubber mallet to realign furniture legs or gently tap in splinters
- Wood glue in a precision bottle for small cracks or loose wood joints
- Fine putty knife to smooth repaired areas before repainting
- Sandpaper in different grits
- Connector fittings (corner braces, dowels, etc.) in case original parts need to be replaced
I would like to know what kind of damages or repairs you specifically have. Are you dealing more with hinges that no longer hold, or damaged edges? Some repairs also require special tools, for example clamps for pressing together glued parts. Additionally, I recommend always using the correct torque when tightening screws again, as otherwise the wood can be damaged.
If you need help with specific steps, just let me know!
jeix9
29 May 2023 20:03
I’ll add a quick note: A hex key set is essential because many IKEA screws use this drive type. I also recommend a combination plier for small leverage tasks and to remove any broken dowel remnants.
Paxton38
30 May 2023 08:27
Dilen schrieb:
I would like to know what kind of damages or repairs you specifically need to address.
From my experience, the most common repairs for HEMNES furniture are:
- Loose screws in the frame or hinges
- Torn dowel joints
- Small cracks in glued joints
- Warped door hinges
For these cases, I find a set of the following tools useful:
- Cordless drill with bits for crosshead (Phillips), slotted (flathead), and hex (Allen) screws
- Wood glue with a narrow applicator tip
- Clamps to hold glued parts under pressure while drying
- Sandpaper with grit between 120 and 240
- Rubber mallet to apply pressure without causing damage
- Knife and, if needed, a small file for touch-ups on wooden trims
Special power tools are not necessary for standard repairs. What matters is a steady hand and proper preparation – for example, using original screws or suitable replacement parts. For heavily damaged components, sometimes a well-fitted replacement achieves better results than repairs, but the two approaches are not mutually exclusive.
V
vinpau
30 May 2023 10:15
Hey tinoben! It’s great that you want to tackle the repairs yourself 🙂
I’d suggest having a spirit level on hand, especially when working with carcasses and cabinet doors, as it makes a big difference to ensure everything fits properly and isn’t hanging unevenly. Also, a small set of precision screwdrivers is useful in case you need to fine-tune any fittings—often the screws are tiny! And a well-lit workspace really helps, otherwise it’s easy to miss small details.
Good luck, you’ll manage it! And if you like, share here how it went!
tinoben
31 May 2023 11:47
Paxton38 schrieb:
For severely damaged parts, sometimes a precisely fitting replacement can achieve better results than repairs.
Thanks for the advice, Paxton38. That’s an important point. In my case, it’s mainly loose screws and hinges that have some play. I also have a few minor tears on the cabinet body that I want to glue shut with wood glue.
I find the idea of using clamps to hold parts in place while drying helpful; I haven’t done that before. I’ll also get some hex keys since that sounds like a frequently used tool.
What do you think about setting up a small workshop box with basic tools for a project like this? Is it worth it, or is it better to buy tools individually as needed?
