ᐅ Which tools are useful for assembling the IKEA Hemnes furniture?
Created on: 31 Oct 2018 08:13
Putanja56
I am currently planning to assemble my IKEA Hemnes wardrobe but am unsure which tools would be best to use. The manual usually lists only the basic tools, such as the Allen key included in the package, but I believe that some additional tools could make the assembly significantly easier or more efficient.
The wardrobe, with its numerous screws, nails, and possibly dowels, does present a challenge. Therefore, I would like to know:
Which tools are useful and recommended for assembling the IKEA Hemnes? Should I use power tools in addition to the included tool (usually a small Allen key)? Or is it worth having a special screwdriver, a cordless drill, a hammer with certain features, or something else?
I look forward to specific tips, preferably with explanations of why these tools really help.
Thank you in advance!
Putanja563 Nov 2018 09:10fasau schrieb:
A cordless screwdriver is your best friend!Thanks for the feedback!
How powerful was your cordless screwdriver approximately (in volts or nm torque)? I have a 12 V, and it doesn’t work very well, even when I set the torque low. Do you think a stronger 18 V is really necessary, or is it more about the design of the screwdriver?
Also: Would you use or recommend a pre-drilled set from IKEA, or prepare everything yourself from scratch? Pre-drilling can save a lot of effort, right?
Summary and precise recommendations for tools when assembling the IKEA Hemnes:
- Allen screwdriver or bits matching the supplied screws
- Cordless drill/driver with adjustable torque; 12–18 V (volts) is sufficient, 18 V offers convenience but is not mandatory
- Rubber mallet for gently fitting wooden dowels
- Flat Phillips screwdriver for occasional cross-head screws
Pre-drilling is usually not necessary, as IKEA drills the holes with millimeter precision.
Important: Set the torque correctly to avoid damaging the wood. Over-tightening can cause material damage and an unstable structure.
Regarding the use of advanced tools (angle attachments, flexible bits), there is little benefit, since the Hemnes assembly mostly involves straightforward, direct access to screw points.
The choice of tools should be based on the furniture description and screw types, prioritizing simple yet precise equipment.
This should be a reliable recommendation both for beginners and experienced builders.
