ᐅ Which tools are most helpful for assembling the IKEA Metod kitchen system?
Created on: 24 Jul 2023 09:23
RuelminHello everyone,
I’m planning to assemble an IKEA Metod kitchen cabinet system in the next few days and want to be well-prepared to make the installation as efficient and smooth as possible.
Which tools have you found most helpful for assembling the IKEA Metod? Specifically, I’m interested in which hand tools or power tools you have found really useful for tasks like aligning the cabinets, securely fixing the back panels, or attaching the fronts. Tips on special tools that aren’t included in the IKEA box but can make the work significantly easier would also be great.
Looking forward to your recommendations, preferably with brief explanations of why you use or recommend these tools.
The assembly of the IKEA Metod system is generally well designed, but a few additional tools can greatly simplify the work.
I recommend:
- A good cordless drill with adjustable torque to avoid damaging the particleboard.
- A spirit level to ensure the cabinets are perfectly aligned.
- A hammer for minor adjustments and inserting dowels.
- A rubber mallet, which is very useful for fitting the cabinet back panels without damaging the surface.
- A tape measure, as the plans sometimes don’t show all the measurements you want to verify right away.
I can only confirm that recommendation. Especially with the large number of screws, it makes a real difference.
If you have any further questions about the assembly, feel free to ask.
I recommend:
Jorgela schrieb:
I would definitely recommend a cordless drill.
In addition to the previous tips, I recommend the following tools for a fast and quality-focused construction process:
- Cordless screwdriver with adjustable torque control and quick-change chuck
- Spirit level, ideally 60cm long (24 inches), for precise alignment
- Measuring tape (at least 5 m (16 feet))
- Carpenter’s square or try square to ensure clean, right-angled joints
- Rubber mallet for gentle assembly of shelves
- Phillips and flathead screwdrivers (in addition to the cordless screwdriver for fine work)
These tools help achieve an efficient and clean result when assembling flush-mounted Metod fronts and securely attaching the back panels.
Important: Using a spirit level and a square prevents later adjustments caused by misaligned fronts or uneven cabinet carcasses.
Great topic here! I can only say: A cordless drill is an absolute must-have; it makes assembling so much fun! 🙂
My tip: Take your time with a good spirit level, it’s really important that everything is properly aligned – otherwise, you’ll be frustrated later when opening the doors.
I also had a small rubber mallet with me, which I used to gently secure the back panels. And a good Phillips screwdriver really helped me with the fine adjustments of the hinges!
Very important: Stay patient, the assembly works great with the right tools and a bit of motivation! You can do it!
