ᐅ Which tools are recommended for modifying Ikea Hemnes furniture?
Created on: 11 Apr 2022 08:24
meo47
meo47
11 Apr 2022 08:24
Hello everyone, I am currently planning to remodel an Ikea Hemnes wardrobe and am looking for recommendations on which tools have proven to be particularly suitable and effective for such projects. I am interested not only in tools for disassembling and reassembling but also for adjustments like shortening doors or reinforcing the structure. Which tools, brands, or special aids would you recommend for this kind of remodel, especially if you want to carry it out as cleanly as possible and without causing major damage to the furniture? Are there any tips on what to consider when choosing tools? Thanks in advance for your experiences!
Mekau
11 Apr 2022 09:17
For the renovation of the Hemnes, I would definitely recommend a cordless drill, ideally with variable speed. Also, a sharp knife and a cordless screwdriver for assembly. Sandpaper can be useful in case minor adjustments are needed.
Leonardteo
11 Apr 2022 11:42
The recommendation for a cordless drill is very accurate. I would also add that for precise trimming of doors, a circular saw with a guide rail is essential to ensure straight cuts. For finishing work, such as smoothing edges, sanding blocks or a random orbital sander work well. It is also useful to have a screwdriver with interchangeable bits on hand, as the typical eccentric screws used by Ikea sometimes require special bits.
V
Victor54
11 Apr 2022 13:08
I am a bit more critical on this. Cordless drills are certainly convenient, but not all provide enough torque to reliably drill through thicker panels without slipping or overdriving the screws. In this case, a corded drill would be more advantageous, especially if you often work on such furniture. Additionally, the quality of the saw blades should be considered, as it is often underestimated. A cheap saw blade can wear out quickly.
JAFUHAU
12 Apr 2022 07:36
I understand the concerns about the tools and also thought I could manage with my basic equipment, but when I first tried to adjust a Hemnes door, I was really frustrated because the cuts didn’t come out clean. It encouraged me when someone suggested using a random orbital sander. Since then, my results have improved a lot, even though I’m still nervous before making the first cuts. You always learn as you go.
edisondan
12 Apr 2022 10:51
In summary, the following tools are recommended for the Hemnes renovation: - Cordless or corded drill with variable speed - Cordless screwdriver with appropriate bits, especially for Ikea eccentric connectors - Circular saw with guide rail for precise cuts - Orbital sander for finishing edges - Sanding block and sandpaper of various grits When selecting tools, a balance between power, handling, and precision should be aimed for, depending on the scope of the renovation. The quality of consumables such as saw blades and bits is also important to ensure clean workmanship.
