ᐅ Which tools are especially helpful when assembling Ikea Metod kitchen units?
Created on: 10 Mar 2022 08:07
Dakuli
I am currently facing the challenge of assembling an Ikea Metod kitchen system and want to prepare as best as possible in advance. The manual is comprehensive, but I am looking for tools that are especially helpful for installing Ikea Metod and that really make the work easier.
Which tools are particularly useful when assembling Ikea Metod? I’m not only referring to standard household tools, but also to special aids or items that have proven to be indispensable in everyday use. I am especially interested in tools recommended for assembling the cabinets, doors, and particularly for mounting them to walls – and what to watch out for to avoid mistakes or damage.
I look forward to tips, personal experiences, or also advice on which tools might be overrated.
[@BENBI] Thanks for asking. I have a standard brick wall, so drilling will definitely be necessary.
The issue of screw depth worries me a bit because I don’t want to damage the slats or carcasses. How exactly do you set a depth stop, or how can you tell if you’re not drilling or screwing too deep? Does anyone have specific experience with this?
In general, I’m also interested to know if there are any special tools for installing the doors that make handling easier, as I understand the hinges for IKEA’s Metod system can be somewhat challenging.
Thanks for the tips so far, I’m looking forward to more feedback.
Dakuli schrieb:
How exactly do you set a depth stop, or how can you tell if you’re not drilling or screwing too deep?Setting the depth stop is actually straightforward: the length should be adjusted so that the screw just penetrates and holds the material together without damaging the interior. Some cordless screwdrivers have a ratchet or other mechanism that you turn until the drill or driver slips.
Alternatively, you can attach a small piece of wood as a spacer on the drill bit and use that length as the drilling depth.
Regarding doors: there are special hinge drill bits that drill more precise and round holes, which makes fitting the hinges easier and improves stability. However, these are not absolutely necessary if you work carefully.
Tip for hinges: after installing the hinges, fine-tune the adjustment screws as needed, since small inaccuracies quickly become noticeable.
angel schrieb:
Tip for the hinge: After installing the hinges, fine-tune the adjustment screws here and thereExactly, fine-tuning is really important. At first, I thought everything was aligned well, but only a precise adjustment made the doors fit perfectly.
Regarding the drill depth stop: I also made a small depth stop myself – a piece of wood with a hole drilled to the right length that slides onto the drill bit. It was very helpful and saved me from constantly measuring.
Dakuli schrieb:
Does anyone have concrete experience with this?Yes, I suggest the following approach:
1. Determine the screw length: Choose a screw that securely fastens the component without protruding through the other side.
2. Set a depth stop: If your cordless drill doesn’t have a depth stop, you can purchase a drill bit depth stop accessory or use heat shrink tubing on the bit as a visual limit.
3. Drill test holes: Always test on scrap pieces to ensure the drill bit doesn’t go too deep.
4. For Metod doors: The hinges are really the critical points; it’s often helpful to have an extra hand when aligning them, such as a small hinge jig or furniture blocks as support.
5. A router with a chamfer bit or sandpaper is suitable for smoothing edges with slight fitting inaccuracies.
I’ll ask again: Is the kitchen screwed together or glued to the floor? Different tools and techniques are needed for each method.
Adding to the discussion here: A square tool for precisely positioning the upper cabinets is a great tool. It helps you hang the cabinets perfectly at right angles without many attempts.
I also recommend investing in good drill bits (suitable for stone/brick). Cheap drill bits break easily, which wastes time and materials.
And very important: a good headlamp or sufficient lighting so you can work accurately even in darker corners.
BENBI schrieb:
I’m asking again: Is the kitchen screwed together or glued to the floor?I plan to screw the individual modules to the wall and to each other, not to glue them.
Thank you very much for the detailed explanations regarding depth stops and door hinges. The idea of using heat shrink tubing is great—I will definitely try it.
I’m still wondering: Does it make sense to wear gloves while working? Or does it interfere with handling the small screws and door frames?
Looking forward to hearing more opinions.
