Hello everyone, I am currently planning to assemble an IKEA Platsa wardrobe and want to make sure I have all the essential tools ready before I start. The IKEA instructions are quite clear, but I have often read that certain tools are really necessary to ensure everything fits properly and no parts get damaged. I am especially interested in which tools you consider absolutely essential for assembling the Platsa – starting from drills, cordless screwdrivers, screwdrivers, spirit levels, or even special accessories like wall plugs or a hammer. Are there tools you find absolutely indispensable without which the assembly unnecessarily drags on? What about the quality of the tools—do I need to pay special attention to anything there? I look forward to your experiences so I can get off to a good start!
Hey Non_reo, great that you’re putting so much thought into this – it definitely pays off! 😄 For assembling the Platsa, I’d mainly recommend a good cordless drill driver, preferably with adjustable torque to prevent over-tightening screws and save a lot of time. Additionally, have a Phillips screwdriver handy in case you need to reach tight spots or tighten something manually. A hammer is useful, especially if you need to insert wall plugs – the Platsa assembly instructions often require some parts to be simply tapped in. Don’t forget a spirit level, which is essential to make sure the cabinet isn’t crooked afterwards! Oh, and for small details, I’d suggest a pair of pliers or maybe even a putty knife if you need to install trim. With these tools, the assembly is really enjoyable – and the result looks professional! 👍 Good luck, and let me know if you have any questions!
Hello Non_reo, I’d like to provide my recommendation in a clear and structured way, as the Platsa cabinet does require some specific tools. 1. Cordless screwdriver: make sure it has an adjustable torque setting to avoid damaging the screws. 2. Spirit level: essential for correctly aligning and securing the cabinet after assembly. 3. Claw hammer: useful for dowels and minor assembly tasks. 4. Phillips screwdriver (PH2): for fine adjustments or when areas are hard to reach. 5. Tape measure or measuring tape: for precise measurements of the installation area. A tip: avoid using very cheap tools, especially cordless screwdrivers, as low quality can cause screws to strip easily! Tip: To prepare, have all tools ready before you start assembly so you can work efficiently without interruptions. If you need to install electrical outlets or drill holes, a drill might be helpful, but it is generally not strictly necessary for the Platsa cabinet. Overall: Good preparation with the recommended tools will save you a lot of time during assembly and help avoid frustration.
SUDAN schrieb:
1. Cordless screwdriver: definitely with torque control to avoid damaging the screws.That’s exactly what I experienced! Without torque control, I nearly ruined a screw on my first flat-pack project. Having to buy replacements and make repairs was really unnecessary. With the right tool, everything goes smoothly! 😊
One more tip: If your cordless screwdriver has an LED light, it makes working in dark corners much easier. Really very helpful!
Marlenepa4 Jun 2021 14:49Hello Non_reo, I have assembled the Platsa cabinet several times and can tell you from experience: careful preparation of your tools really makes a difference. The most important tool is a reliable cordless drill/driver with various bits, including Phillips PH2 and flathead. This way, you can adapt flexibly if the instructions call for a different type of screw. A spirit level is essential, especially for Platsa, because the modules are often anchored to the wall or stacked on top of each other. Checking each part with a spirit level before connecting the modules will save you trouble later. Additionally, I always use a tape measure to measure the wall area, and make sure you have enough wall plugs (anchors) suitable for your wall type and a hammer to tap them in. A tip: try screwing into some wood with your bits beforehand to ensure they hold well and don’t slip, which protects both the wood and the screws. If you need to attach the back panel, a small rubber mallet can be helpful. Regarding tool quality, I recommend not to skimp—especially inexpensive cordless drills can quickly lose power or apply too much force on the screws, causing problems. I hope this helps!
