I am currently planning to modify my Ikea Hemnes wardrobe to make it more functional. In this context, I am wondering: which tools are truly essential for such a renovation? I don’t just want to take it apart and put it back together; I also plan to make some adjustments, such as drilling new holes or modifying certain parts. Which tools should I have on hand to work professionally and minimize any damage to the materials? I would appreciate a detailed list and tips on how to use them.
Kenmi57 schrieb:
Which tools are really essential for this kind of renovation?You can manage well with these tools:
- Cordless drill with appropriate bits
- Phillips and flathead screwdrivers
- Drill (for making new holes)
- Spirit level
- Measuring tape or folding ruler
Usually, you don’t need anything more.
Kenmi57 schrieb:
Which tools should I have ready to work professionally and with as little damage to the materials as possible?For a well-organized Hemnes modification, I recommend a set of the following tools and aids:
- Cordless drill driver: For removing and reinstalling screws; pay attention to the battery charge.
- Drill with wood drill bits: Especially if you need to make new holes; pre-drilled holes or metal brackets require precise drilling.
- Screwdriver set (Phillips & flathead): For adjustments and manual tasks.
- Angle finder or small spirit level: To align the cabinet straight after modifications.
- Measuring tools (tape measure, caliper): For accurate measurements during the modification.
- Sandpaper or small file: For smoothing edges after drilling or cutting.
It is important to keep screws and fittings organized during the modification and to work precisely to avoid damage to the wood. A foam pad can also protect the workpiece from scratches.
I would like to share some important practical tips regarding the Ikea Hemnes modification, especially in response to Kenmi57’s question:
- Start with a good cordless drill, preferably one with a torque adjustment. This prevents screws from being driven in too deep, which can often damage the wooden panels.
- For new drill holes, I recommend using a drill bit with a thin tip for pilot drilling to guide the wood better. After that, you can enlarge the hole with a larger drill bit.
- Use a tape measure and a spirit level, but mark your measurements definitively only when you are certain – small adjustments are normal.
- A utility knife or a fine carpet knife can be helpful for scoring tape or cutting protective films if you want to remove the protective coverings from the panels.
- For sanding, I recommend fine sandpaper (grit 240 or finer), especially to smooth cut edges.
- I also suggest having a small screwdriver set, useful for unusual screws or for adjusting knobs.
If you are unsure with the drill, practice drilling on a scrap piece of wood first. The general rule is: patience is the best preparation to avoid mistakes.
One more thing: the modification will be easier if you have a flat, clean working surface and all parts organized and sorted.
