ᐅ Which tools are best suited for assembling Ikea Besta units?
Created on: 14 Mar 2019 08:27
Guman
Guman
14 Mar 2019 08:27
Hello everyone, I am planning to assemble an Ikea Besta shelving unit and want to prepare the right tools in advance to save myself as much effort and hassle as possible. My specific question is: What tools are ideal for assembling Ikea Besta, especially considering the included fasteners and the commonly used dowels, screws, and cam locks? Are there any recommendations for certain screwdrivers, wrench sizes, or maybe useful extras that make the process significantly easier? I have heard about cordless drills but am unsure how much power is really necessary without risking damage to the material. Additionally, I would be interested in tips on how to achieve a particularly clean and precise assembly. I look forward to your experiences and recommendations!
Elodie
14 Mar 2019 09:13
Hello Guman! Your question is very detailed and shows that you want to be well prepared – that’s already half the battle. 😉 For the Besta flat-pack kit, I definitely recommend having a good Phillips screwdriver ready, ideally a PH2, as most screws fit that perfectly. A cordless drill with adjustable torque is very helpful so you don’t overtighten and damage the wood surfaces. 👍
I also suggest having a small hammer, preferably made of rubber or softwood, for the dowels. This helps to insert the connectors more smoothly without damaging the surfaces. And if you have trouble with the cam locks: an Allen key of the right size (usually 4 mm) is your friend.
One important thing: be patient and assemble each part carefully so that everything ends up stable in the end. Good luck with your furniture project!
sifa65
14 Mar 2019 10:02
Guman, I can confirm the recommendation for PH2 screwdrivers and hex keys. It is also important that the cordless drill does not operate at too high a speed, as this can damage the screws and wooden panels. Models with torque control and adjustable speed are recommended.
Additionally, my experience shows that a small tape measure helps with precise alignment, as does a square for checking right angles during assembly. A small tip regarding dowels: before gluing or inserting them, quickly check that they are not set too deep, as this can otherwise affect stability.
Patience is a virtue, but the right tools also make assembly significantly less stressful.
LEEJU
14 Mar 2019 11:27
Briefly: A cordless screwdriver with adjustable torque, a PH2 Phillips bit, and a 4mm (0.16 inch) Allen key. A hammer for driving in the anchors. That is more than sufficient.
theota
14 Mar 2019 14:19
Elodie schrieb:
A cordless screwdriver with adjustable torque is really helpful so you don’t overtighten and damage the wood surfaces.
I see it a bit differently. A cordless screwdriver is convenient for assembling IKEA furniture, but if you don’t have the necessary finesse, you can damage the furniture faster than you can say “Besta.” Sometimes, a good old screwdriver is enough – it simply gives you more control than a power tool that can easily overwhelm you.
Besides, I generally wonder if all these tools are really necessary. Less is often more. Besta is meant for DIYers who don’t need professional-grade machines and can be satisfied with minimal equipment. The mix of materials doesn’t have to be over-engineered.
REPITAR
14 Mar 2019 16:53
To support the assembly of the Ikea Besta shelving unit effectively, I have put together a brief guide with tool recommendations:
- PH2 Phillips screwdriver or a cordless drill with adjustable torque
- 4 mm hex key (for cam locks) – usually included in the kit; if not, be sure to get one
- Rubber or softwood mallet for dowels
- Optional: protractor or carpenter’s square to check right angles
- Tape measure for precise alignment
Important: When using the cordless drill, make sure the torque setting is low to avoid damaging the wood. Apply steady pressure when tapping in the dowels and avoid hitting too hard.
Common mistakes: overtightening screws, over-turning cam locks, or jamming dowels. It’s best to regularly check during assembly that everything still fits properly.
This combination of tools ensures a stable construction and protects the materials over time.
