Hello everyone, I am planning to assemble several Billy shelves from IKEA soon and am looking for recommendations and experiences regarding which tools are helpful for the assembly. Which tools make the process easier, especially for fastening and fitting the shelves? Are there any special tools that make the assembly more stable, faster, or simpler? I already have a screwdriver and a hammer but am open to suggestions for cordless drills, spirit levels, or other useful aids. Thanks in advance for your tips!
Hello seketar,
to answer your question as thoroughly as possible: When assembling Billy shelves, there are some tools that are helpful beyond a standard screwdriver. First, I definitely recommend a cordless drill/driver with adjustable torque, as the included screws should be driven in precisely and with little force to avoid damaging the particleboard.
Additionally, I recommend a spirit level or at least a small one, since the shelves should be aligned exactly to prevent the shelves from hanging crooked later. A combination square or angle tool can help ensure the corner is perfectly square after screwing in the connector fittings.
If you want to drill pilot holes beforehand or add extra screw holes for brackets, a drill with a fine wood drill bit (about 3-4 mm (0.1-0.15 inches)) and a cordless screwdriver are very helpful.
One more tip: Pliers can help if a nail or dowel gets stuck, and a rubber mallet is useful for gently tapping the back panel into place.
If you pay attention to these details, assembly will not only be faster, but the shelves will also be sturdy and look professionally installed.
Which tools are you currently using? Maybe I can assist you specifically with additional recommendations.
gauvin37 schrieb:That’s correct – a hammer is useful for wooden dowels or plastic expansion dowels. However, I advise tapping the dowels in carefully to avoid splitting the wood, so a light tack hammer or rubber mallet is better suited than a regular steel hammer.
You only need a hammer for the dowels
A very interesting approach from TEBILO, linking the quality of construction indirectly to the tools used.
It’s also worth considering that not everyone has technical equipment like a spirit level or a square at home when doing DIY. Maybe it’s possible to work without these special tools by using certain tricks, for example, relying only on feel or basic aids.
I’m curious if anyone here has had better or worse results working entirely without these extra tools. A kind of experience comparison could show whether investing in additional equipment is worthwhile or if simplicity and experience are sufficient.
TEBILO schrieb:I think this is a crucial point. The particleboard of the Billy shelves is not particularly sturdy. Where I see more room for discussion is the general necessity of a cordless screwdriver: Sometimes, isn’t a good manual screwdriver enough?
A cordless drill driver with adjustable torque [...] to avoid damaging the chipboard.
