ᐅ Which tools are essential for assembling the IKEA PLATSA system?
Created on: 21 Apr 2021 18:47
Pife63Hello everyone, I am about to assemble my IKEA PLATSA system and want to make sure I have all the necessary tools ready beforehand. My question to the community is: Which tools are essential for assembling IKEA PLATSA to work efficiently and avoid damage? Of course, I am aware of the usual tools like screwdrivers and hammers, but I would like to know if there are any specific tools that make the assembly easier or even necessary to ensure the structure is stable and the installation goes smoothly. I am also interested in whether using a power drill is recommended or if it is better to rely on the provided components. I would appreciate any tips and experiences, including details about the individual tools!
The question of which tools are really necessary for assembling IKEA PLATSA is quite reasonable, as it can save time and effort. Basically, you should have the following ready:
- A Phillips screwdriver (PH2), since many of the screws have a Phillips head
- A rubber mallet or a regular hammer with a wooden block for protection, in case parts need to be adjusted
- A tape measure to check dimensions during assembly and alignment
Regarding a power drill, it is usually not essential because IKEA panels are often pre-drilled, and wood screws can be driven in by hand. However, a cordless screwdriver, if available, can significantly speed up the assembly, as long as you are careful not to overtighten and damage the material. An Allen key is normally included and does not need to be purchased separately.
Patience and careful alignment of the modules are also helpful to ensure a stable construction.
I would like to go into more detail on this topic, as PLATSA is indeed a modular furniture series characterized by specific assembly methods. For a well-planned and smooth assembly, I recommend the following tools and procedures:
- Phillips screwdriver: Depending on the screw type, PH2 or PH1. Precision is especially important here to avoid damaging the screw heads.
- Cordless drill with adjustable torque: Highly recommended for driving screws to prevent over-tightening the material. Make sure to use a short bit set so you can work easily in tight corners.
- Rubber mallet: Important for gently fitting or positioning the connectors without causing damage.
- Spirit level: Train-style design aside, you cannot align the shelving unit accurately without a spirit level. This is essential, especially when stacking multiple modules.
- Clamps (optional but helpful): To temporarily hold parts in place before screwing them together. This significantly eases the assembly process.
- Tape measure or folding rule: For precise measurement, particularly when customizing the PLATSA system.
Regarding the included Allen keys: they are adequate, but using a small ratchet or torque wrench with an Allen bit makes the work much more comfortable and precise. With the PLATSA system, it is especially advisable to follow the system instructions meticulously and to align the individual rails and holes exactly, which is much more difficult without the right tools due to the lightweight structure.
One more tip: Check all parts for damage and ensure you have the correct quantity before starting assembly. This saves stress during the build.
I’m also interested in whether you plan to connect multiple modules or build standalone units, as this affects the choice of necessary tools.
kulau schrieb:
I’m also curious whether you plan to connect multiple modules or build standalone units?That’s a good question and really depends on which tools you prioritize. If you assemble multiple modules, proper alignment and securing using a spirit level and, if necessary, clamps are definitely essential.
Additionally, I would define my recommendations as follows:
- Essential: Phillips screwdriver (PH2), hex key (often included), measuring tape.
- Useful: Cordless drill with torque control, rubber mallet.
- Optional but often helpful: Spirit level, clamps.
An electric drill is generally not recommended for PLATSA, as it typically uses thinner screws that can easily be installed by hand or with a cordless drill to avoid material damage.
The best advice is to take your time and, above all, read the provided instructions carefully. This helps prevent mistakes and frustration, especially with more complex or combined units.
