ᐅ Which tools are essential for assembling the IKEA Brimnes furniture?
Created on: 18 Oct 2024 09:37
Aton41Hello everyone, I am currently planning to assemble the IKEA Brimnes wardrobe and want to make sure I have all the necessary tools ready before I start. Therefore, my detailed question is: based on your experience, which tools are essential for assembling the IKEA BRIMNES to complete all assembly steps smoothly and avoid common difficulties from the outset? I am particularly interested in whether, besides the included Allen key, other tools like screwdrivers, a hammer, or a drill could be useful. I would appreciate any tips on tools that can significantly simplify the assembly, reduce the time required, or improve the stability of the wardrobe. Thanks in advance for your recommendations!
Hello Aton41, that’s a very good and practical question, one that should be asked often before starting the Brimnes assembly. Here is a structured overview:
- Included hex key: It is of course necessary, as it is intended for most of the screws. However, it does not replace a proper screwdriver.
- Phillips screwdriver (PH2): This is very useful for most of the screws used in the Brimnes, as it makes the work safer and faster than using the hex key alone.
- Hammer: Important for lightly tapping in dowels and nails if the instructions require it. A small claw hammer is ideal for this.
- Optional: Cordless drill with a Phillips bit – if you have experience, this significantly speeds up the assembly and reduces tiring manual work. But be careful—not too much force, as it can damage the wood and screws.
My advice: Above all, take your time and check before you begin to make sure all screws and parts are present. A well-equipped screwdriver set with various bits is invaluable. I often see people trying to work with only the hex key, which results in much longer assembly times. Good preparation saves frustration during the build.
Hello Aton41, thank you for your detailed question. I believe it is important to evaluate tools not only based on whether they are "necessary or unnecessary," but also considering efficiency and safety. Based on my experience, I can suggest the following tools:
- Spirit level: Especially for a large piece of furniture like the BRIMNES, it is important to align everything before final tightening to avoid any wobbling or unevenness later on.
- Folding ruler or tape measure: To precisely maintain distances and check that everything fits correctly.
- Rubber mallet instead of a regular hammer: To gently tap connectors or dowels into place without causing visible damage to the wood.
However, I also see the risk that, especially with inexpensive IKEA furniture, screws can be overtightened and damage the material. My advice: use a cordless screwdriver only with a torque limiter, or better yet, tighten critical screws manually step by step.
I am curious: Have you assembled furniture yourself before, or is this your first project? This would influence the choice and importance of the tools.
Jensson schrieb:
Optional: Cordless screwdriver with Phillips bit – if you have experience, this can speed up the assembly significantly and reduce tiring manual work.
The IKEA BRIMNES features a standardized assembly system that primarily relies on cam lock fasteners and wooden dowels. The main tools required for assembly are therefore:
- Standard Allen key (included)
- Hammer, preferably a rubber mallet
Power tools such as cordless drills are less relevant since the material (particleboard) is sensitive to overtightening. A spirit level is only necessary if the unit needs to be precisely leveled later, which is often compensated by the floor with this type of shelving.
Summary:
- A screwdriver and hammer are essential tools for assembly.
- Cordless drills are optional and recommended only if used carefully.
I also recommend sorting all screws and parts systematically before starting the assembly to avoid unnecessary searching. This significantly increases efficiency.
Summary:
