ᐅ Which tools are best suited for assembling the IKEA Brimnes furniture?
Created on: 17 Jan 2020 08:34
AnkabuHello everyone,
I am planning to assemble the IKEA Brimnes wardrobe myself and would like to know in advance: based on your experience, which tools are best suited for assembling this model? I am particularly interested in which hand tools or possibly power tools are really useful to put together the furniture set efficiently, without damage, and as safely as possible.
I am also curious whether the included tools are sufficient or if it is better to use your own equipment, and if so, what you would specifically recommend—for example, cordless drill, sizes of hex keys, an additional hammer, or similar. I look forward to your tips and experiences!
here is a brief guide on which tools are useful:
- Allen keys: The Brimnes is usually supplied with Allen screws, mostly 4 mm. The included tool is okay, but a high-quality Allen key is more comfortable to use.
- Cordless screwdriver: Recommended with adjustable torque to avoid over-tightening screws or damaging the material.
- Rubber mallet: Useful for joining dowels or wooden connections quickly and without damage.
- Needle-nose pliers or combination pliers: Can be helpful when small metal parts need to be turned or pulled.
Avoid large hammers or drills without torque control, as these can cause damage to the frame or screws.
When assembling the IKEA Brimnes, the following tools should be considered:
- The included tools are functional but often of lower durability. A sturdy 4 mm hex key (Allen wrench) is beneficial.
- A cordless drill with adjustable torque makes screwing easier and helps prevent over-tightening. Important: set the torque as low as possible since the furniture is made of particle board.
- Additionally, a rubber mallet is recommended for inserting dowels or gently adjusting the components.
- If available, a small Phillips screwdriver can be useful for securing any screws if needed.
The goal is a safe, careful assembly without damaging fittings or furniture panels. A regular hammer is rather counterproductive.
giabau schrieb:
Rubber mallet: Useful for quickly assembling dowels or wooden joints without causing damage.Thanks for the tip about the rubber mallet. Is a small, standard rubber mallet from a hardware store sufficient, or do you recommend specific sizes or quality features? I want to avoid damaging surfaces or wooden edges by applying too much force or using the wrong tool.
