sebastian15 Oct 2020 08:23Good morning everyone,
I recently purchased a Malm bedroom furniture set made of light wood (partially solid pine with veneer). Now I am wondering which type of surface care is best suited for these Malm pieces to protect the material in the long term, preserve the natural character, and avoid any unsightly stains or discoloration.
I am especially interested in information about different care products such as furniture wax, wood oil, special wood care products for veneered surfaces, or possibly mild cleaners. I would also like to know if there are any restrictions, for example, no oils on veneered surfaces, or any specific recommendations from IKEA or user experiences.
Does anyone have practical experience or proven tips for surface care of Malm wood? Which care products can be used without concern and what should be avoided? How often is treatment recommended?
Thanks for your answers – detailed, factual information is very important to me!
I think, for such specific furniture, it’s best to first consult the manufacturer’s instructions. IKEA usually does not recommend any special oil or wax for MALM—I understand this is because the surface has a melamine resin coating, which is quite resistant.
Exactly, because melamine foil or plastic layers don’t always tolerate oily products. Oil doesn’t really absorb and can leave unsightly marks.
I’m wondering about the long-term disadvantages of using furniture wax anyway. Are there reliable experiences? Or is there a risk that the surface becomes sticky and attracts dirt?
sebastian1 schrieb:
whether there are any restrictions, for example no oils on veneered surfaces?
Basically, the surface of MALM furniture is usually coated with melamine, which is more like a plastic layer than real natural wood. Therefore, oils or waxes hardly penetrate and are often unnecessary—sometimes even counterproductive.
If it is made of partially solid wood, for example tabletops, it may be possible to treat them with wood oil according to the manufacturer’s instructions to maintain the surface. However, you should definitely pay attention to IKEA’s product information here.
Tip: For daily cleaning, simply use a soft, damp cloth without aggressive agents. If you want to apply a protective layer, a furniture cleaner or conditioner specially designed for coated surfaces is recommended.
It is important not to apply waxy or oily products to the laminate surfaces. These can become dull or sticky, attracting dust.
Do you have more detailed information on whether your MALM furniture is only veneered or coated on the surface, or are there parts made of solid wood?
sebastian15 Oct 2020 13:02liste schrieb:
IKEA usually does not recommend any specific oil or wax for MALM – I understand this is because the surface has a melamine resin coatingThat’s exactly right; the surface is almost entirely coated, except for a few visible edges made of solid wood.
minan schrieb:
Do you have more detailed information... or are there areas made of solid wood?Yes, the edges and back panels are made from solid pine wood.
I’m interested in whether these solid wood parts require different care compared to the main frames and fronts, which are veneered or coated.
Can I use wood oil on the edges, or would that not make any visible difference compared to the coated surfaces? Or is treating them only necessary if the solid wood areas become rougher?
Otherwise, it seems that regular cleaning with a mild detergent is optimal? But would that mean losing the natural wood’s ability to age gracefully if the surfaces aren’t oiled?
This is an important point: Solid wood edges require different treatment than melamine-coated surfaces.
For the edges, I recommend lightly applying a wood oil or a colorless oil-based wood care stick to protect the wood from drying out and to preserve its texture.
The frontal coated surfaces, on the other hand, should only be cleaned dry or with a damp cloth. Waxes or oils are not suitable here.
This differentiated care maintains the visible solid wood and overall appearance without unnecessarily risking the durable plastic surfaces.
