ᐅ Which type of storage tank is suitable for an air-to-water heat pump?
Created on: 11 Apr 2016 22:52
tabtab
Hi,
how large should a domestic hot water tank be for an air-to-water heat pump? Is a separate buffer tank for the heating system necessary? I think I once read that ideally you should avoid using a tank at all, because only then does the air-to-water heat pump operate at maximum efficiency. Is that true or nonsense? What do you recommend? And does coupling it with a thermal storage tank connected to a wood stove make sense to support heating during winter?
Sebastian7924 Jun 2016 09:28Exactly, you are the customer – and therefore insignificant.
Ultimately, you could be criticized for the missing thermostats – or have you officially been exempted?
Sebastian7924 Jun 2016 09:38It can’t be changed anymore anyway – neither for you nor for me.
Yesterday I turned on the hot water for the first time – what temperature do you set it at and with what hysteresis?
