ᐅ Which replacement parts should IKEA HEMNES owners keep on hand?
Created on: 2 Feb 2022 14:23
Fepamu
Fepamu
2 Feb 2022 14:23
I am starting a discussion on the topic: Which spare parts should owners of the IKEA Hemnes furniture series keep on hand to respond quickly and effectively to common damage or wear? The HEMNES series mainly includes cabinets, dressers, and beds, which are often connected with screws, dowels, hinges, and drawer slides. Since spare parts can sometimes be difficult to obtain individually or cause delays, the question arises: which components should be available in a home workshop or household to carry out small repairs independently or at least make them easier? Who has experience with this or knows which spare parts are most frequently needed, perhaps also in connection with specific accessories or surface treatments that can be retrofitted?
Tobias
2 Feb 2022 14:48
- Screws and anchors in various sizes, as HEMNES often uses different types of screws.
- Replacement hinges for doors, since these experience the most wear.
- Shelf supports (the small metal brackets inside cabinets) are important for shelves.
These are the parts that wear out or get lost most frequently.
Fitigu
3 Feb 2022 09:15
For additional context and better understanding: The IKEA HEMNES system is made of solid pine wood, which can be prone to wear on connectors and moving parts with extended use. Therefore, it is advisable to keep the following spare parts on hand:
- Various Phillips-head screws (M4 and M5), as these are commonly used at connection points
- Plastic dowels matching the screws, as they provide stability, especially in softwood
- Metal hinges from the series, preferably with single-hole mounting plates, since they are subject to dynamic loads
- Shelf supports or brackets, to immediately replace broken or loose sections
- Glides or floor protectors, as these are often lost or damaged and protect the furniture floor
These parts ensure that typical repairs due to mechanical wear can be carried out quickly and cost-effectively. Spare parts for surface treatments should be kept separately, as they depend heavily on the color finish.
rimole
3 Feb 2022 10:47
Fitigu schrieb:
Various Phillips screws (M4 and M5), since most common connection points use these
This is especially important; otherwise, you risk locking yourself out unnecessarily during repairs. Also, you shouldn’t buy replacement screws only from IKEA, as they are often more expensive.
Fitigu schrieb:
Metal hinges of the series, preferably with single-hole fitting
The hinges need to fit well because incorrect hinges can quickly cause problems when closing.
