ᐅ Which replacement parts for the Ikea Brimnes series are the most difficult to obtain?
Created on: 22 Mar 2024 08:34
Kledian
I am interested in which spare parts for the Ikea Brimnes furniture system are the hardest to obtain. Specifically, I mean the most common issues with individual components like drawer runners, fittings, or door hinges. Since Brimnes is offered in several versions with drawers, doors, and wardrobes, it would be helpful if you could share your experiences in detail: Which spare parts are the most difficult to find for a Brimnes wardrobe? Are there any specific parts related to the drawers and their mechanisms that Ikea offers only reluctantly or not at all as replacement parts? I am also curious if you have noticed any differences depending on whether you order online or inquire in-store. Maybe you also know if availability varies regionally. In general, I try to keep this thread as specific as possible to help others who are looking for spare parts for Brimnes.
Kledian
23 Mar 2024 09:12
kulau schrieb:
Are there specific parts causing you trouble? What is your IKEA part number?
Thank you for your explanation. I am referring to the Brimnes 3-door wardrobe in white, item number 703.648.80. Specifically, I am having issues with the drawer slides, which are either worn out or jammed. The runners are no longer stable and are sometimes misaligned. I’m wondering if IKEA sells these slides individually or if the entire drawer needs to be replaced. Unfortunately, I could not find direct replacement parts on their website. Has anyone had experience with the replacement part number for the slides or recommendations on how to source them?
Blavin
23 Mar 2024 10:38
Kledian schrieb:
I wonder if Ikea sells these rails individually or if you have to replace the entire drawer.
With Brimnes, it is typical that Ikea does not offer the drawer slides separately. Instead, the complete drawer is often recommended as a replacement part, which is naturally more expensive and more complicated.
I suggest contacting Ikea’s spare parts department directly to inquire about available options. There are also third-party suppliers that manage to offer compatible drawer slides—however, caution is advised, as dimensions and mounting points can vary, which may result in a poor fit.
Conclusion: The availability of drawer slides as individual replacement parts for Brimnes is generally limited.
Nabla64
24 Mar 2024 08:55
Blavin schrieb:
There are also third-party suppliers who manage to offer compatible sliding rails
Here is a brief guide: If you decide to replace sliding rails with third-party options, you should consider the following points:
- Precise measurement of the existing sliding rails: length, width, height, mounting points, and running mechanism.
- Compare the measurements with products available from specialist retailers, for example, drawer slides from furniture hardware are usually standardized, but some manufacturers like Ikea may use slightly different dimensions.
- Pay attention to load capacity and smoothness of operation – Ikea rails are not always of the highest quality.
- Installation: Sometimes holes need to be drilled or screws adjusted.
If you are unsure, it is better to order original parts from Ikea, even if they are more expensive, to avoid compatibility issues.
GiRoyce
25 Mar 2024 11:02
Nabla64 schrieb:
If you’re unsure, you should order the original parts directly from Ikea, even if it is more expensive
I agree with this. Even though it sometimes takes a bit longer, original replacement parts are always the safest choice.
I would also recommend asking Ikea’s customer service to explicitly confirm the replacement part numbers during the repair. This helps avoid ordering the wrong parts and makes any follow-up questions easier.
If that doesn’t work, you can also check with your local furniture store or professional carpenters for compatible solutions, especially for older parts that Ikea no longer supplies.
