ᐅ Which spare parts are the most important for Malm furniture?
Created on: 21 Dec 2017 19:43
Ixge53
Ixge53
21 Dec 2017 19:43
I am currently looking into the Malm furniture from IKEA, especially the frequently needed replacement parts. My question to the community is: Which replacement parts for Malm furniture are actually the most important and most commonly required? I am thinking of wear parts that typically break, so not just screws but also special mechanisms or drawer runners. Additionally, I am interested in whether there are recommended sources to obtain these parts if you cannot find them at IKEA itself. It would be great if someone with experience could share some tips here.
Aimee
21 Dec 2017 20:12
Usually, the drawer slides are the most important replacement parts for Malm dressers. If the slides stick or are broken, the drawer will not operate smoothly or may not work at all. The small stoppers or dampers on the drawers also often break. Ordering replacement parts directly from IKEA generally works well.
LANICOLE
22 Dec 2017 08:29
Good question. Since Malm is a very common series, there are indeed a few spare parts that are frequently needed. The most important ones are:
1. Drawer slides: These are moving parts that wear out the most from frequent opening and closing. When replacing, make sure to use the correct model number!
2. Machine screws and T-nuts: These can easily be over-tightened or lose their grip, which leads to instability.
3. Cabinet door hinge shafts: Especially on models with doors, these can wear out or bend.
Common mistake: Many try to secure the slides with standard screws, which won’t hold. Always use original spare parts to ensure proper fit.
In summary: The focus is on moving parts, as fixed components are less affected. For sources, besides IKEA, I recommend specialized online shops for furniture spare parts.
Ixge53
22 Dec 2017 10:06
LANICOLE schrieb:
The most important components are drawer slides, cam and dowel nuts, as well as hinge pins.
Thanks, that helps me a lot! I wanted to ask: Are there different materials or quality levels for the runners in Malm furniture? Sometimes I get the impression that cheaper versions tend to break more quickly. Also, how can I tell if the drawer slides can still be repaired or if they need to be completely replaced?
RETRAVIS
23 Dec 2017 16:37
A few precise facts about spare parts for Malm furniture:
Drawer slides are indeed the most commonly needed replacement part, as they undergo significant wear from regular use. IKEA typically uses metal slides with plastic components for Malm, which can wear out over time.
Material differences in the runners are rare since IKEA uses standardized parts for this series, but older versions may vary slightly. It is important to check the model number of the slide when replacing it, as there are several variants.
Signs of damage: If the drawer sticks when opening, rattles sideways, or makes noises, it is usually best to replace the entire slide. Repair attempts on broken plastic parts are often not durable.
Regarding sources: Besides IKEA itself, specialized spare parts suppliers online often offer a wide range of original and compatible parts. Delivery times are often shorter there and the customer service more localized.
In short: priority should be given to drawer slides, hinges, and fasteners. Use original parts to ensure compatibility.
