ᐅ Which replacement parts are most important for Malm drawers?
Created on: 23 Feb 2021 10:12
Lubofe
Hello everyone, I recently got a Malm chest of drawers with several drawers and have noticed that some parts need replacing. Since I want to do the repairs myself, I’m particularly interested in which replacement parts for the Malm drawers are most important to ensure smooth operation. I’m thinking of wear parts like rails, rollers, or handles, as well as specific small components. I’m especially curious about which parts tend to break most often and which ones are best to keep in stock to quickly fix any issues. Thanks in advance for your experiences and tips!
Jamalli
23 Feb 2021 13:15
It would be interesting to know if the wear parts for Malm vary over the years. Some rail models are made of metal, others of plastic. Are there reliable sources or practical experience indicating which version is more durable? Or is the difference negligible?
hauklo
23 Feb 2021 13:42
Jamalli schrieb:
Whether the wear parts for Malm vary over the years
There are indeed different versions of the drawer slides. Older models usually use simple plastic runners, while newer ones often have metal tracks with ball bearings. Metal is generally more durable and provides smoother movement but is more prone to rust in damp environments if not coated.
My recommendation: For frequent use, switch to a metal guiding system. Plastic versions are cheaper but less durable in the long run.
Lubofe
23 Feb 2021 14:05
hauklo schrieb:
My recommendation: switch to a metal guide system if used frequently
Thank you for this assessment! Could you also say something about the end stops? Are they particularly prone to issues with Malm?
bupar
23 Feb 2021 14:48
Stop blocks for Malm drawers are usually made of plastic. They don’t often break but can become brittle over time, especially with frequent use or if the drawer is pulled out completely very often.
Having a spare supply of stop blocks is advisable if the drawer is heavily used. In case of failure, the drawer may slide out uncontrollably, which can be unpleasant and dangerous.
In summary: keep an eye on the runners, plastic glides, and stop blocks. Handles should be checked as needed.
TELAHAU
23 Feb 2021 15:07
If end stops are damaged, a simple replacement is often sufficient since the parts are inexpensive. It is important to order the exact matching type.
FELOTAU
23 Feb 2021 15:22
What annoyed me the most was when the drawer got stuck halfway while opening because the rollers had worn out. Maybe the rollers are even more important than I initially thought.
