ᐅ Which spare parts are particularly important for IKEA HEMNES furniture?
Created on: 29 Aug 2023 09:13
KYLE38Hello everyone,
I recently assembled my IKEA Hemnes bed and noticed that some spare parts, such as screws and wall plugs, were missing, or I am concerned that they might wear out over time with use. I am therefore very interested in which spare parts for the IKEA Hemnes are particularly important to ensure the stability and durability of the furniture. Which components should definitely be kept in stock or checked regularly? Are there parts that, based on experience, tend to break more often or need replacing? I’m also curious whether certain screws or fasteners should be swapped with alternatives to improve longevity.
I look forward to your detailed experiences and advice!
Hello KYLE38,
First of all, that’s a very good question! When it comes to IKEA HEMNES furniture, the fasteners are definitely key. Screws, dowels, and wooden pegs, as well as metal brackets, play a crucial role in stability. I always recommend the following approach:
- Check all screws for tightness and replace any that seem damaged or low quality during the initial assembly.
- The wooden dowels in HEMNES pieces are often made from relatively soft wood. If needed, these can be swapped out for harder or specially coated dowels to prevent splitting.
- Metal brackets are commonly used to secure the back panels. Since many issues involve loose back panels, make sure to use screws with wide heads here.
Replacement screws are usually easy to find at IKEA, but not all parts can be easily swapped out, especially the back panel. Do you have a specific piece of furniture or a more serious defect you’ve noticed? I could give more detailed advice in that case.
Also, I recommend always ordering a small spare pack of screws and wooden dowels — they’re really handy in case any parts wear out or break.
Hello KYLE38,
I’ll give you a brief step-by-step guide to help you assess the most important replacement parts for HEMNES:
1. Check screws: Most HEMNES components are held together with metal screws. Regularly check that they are tight, as connections can loosen over time due to wood swelling or shrinking.
2. Inspect wooden dowels: These ensure the proper alignment of parts and contribute to stability. Over time, they can break or swell. Recommendation: If wooden dowels are missing or damaged, always use original parts or at least comparable high-quality dowels.
3. Back panels and metal brackets: Especially in dressers and cabinets, the back panel often adds to the overall stability and is fastened with small nails or screws. If the back panel becomes loose, be sure to replace the small fasteners.
4. Handles: While not structurally critical, handle screws can wear out with frequent use. If your handles are loose or wobble, it’s a good idea to gently tighten the screws or find suitable replacements.
Important: When buying replacements, always pay attention to the original dimensions, such as the length and diameter of screws. From experience, the connecting screws between the slatted frame and bed frame on a HEMNES bed are particularly important, as they directly affect comfort and safety.
Could you describe which specific HEMNES piece of furniture is affected and which parts are causing concern?
One more tip: If you order replacement parts separately, note down the article numbers of the original parts — this will help you find the correct items faster.
Hey KYLE38, it’s great that you’re thinking about this! I’ve found it useful to always keep a small spare kit of screws and wall plugs for my HEMNES bed in case something comes loose. Especially the screws that hold the slatted frame tend to break depending on the load.
I can definitely confirm that! The stability at the back of the wardrobe is especially important; otherwise, it quickly starts to wobble.
My tip is to always buy the official IKEA spare parts set right away—it saves you hassle and the feeling of having to improvise. You’ll see, it gives you a good sense of security 🙂 Good luck!
kulau schrieb:
Metal brackets are often used to connect the back panels. Since many problems occur with loose back panels, it’s important to use screws with wide heads here.
Hello KYLE38,
your question is really important because many people underestimate how critical small parts can be with HEMNES furniture!
I would add that with complementary pieces, such as nightstands or display cabinets from the HEMNES series, the hinges are often a weak point. The standard hinges from IKEA are solid, but with long-term use, they can loosen or become deformed.
Tip: Keep replacement hinges or original IKEA hinges on hand and occasionally tighten the screws. This prevents rattling and misaligned doors.
Also, pay attention to the plastic screw covers, which protect the screw heads from wear and provide a clean finish.
So, my conclusion: important spare parts are screws, wooden dowels, metal brackets, hinges, and their fasteners. Anyone who prepares in this way will enjoy their furniture for a long time!
Good luck!
Good luck!
