ᐅ Which spare parts are especially important for Ikea HEMNES dressers?
Created on: 29 May 2022 08:17
adolfI recently started using an Ikea Hemnes dresser and noticed that replacement parts are occasionally needed for this type of furniture in everyday use. From your experience, which spare parts are particularly important or most commonly required for Ikea Hemnes dressers? I am especially interested in those parts that help ensure the dresser’s long-term functionality. It would also be helpful if you could briefly explain why these specific parts tend to fail or need replacement, for example due to material fatigue, mechanical stress, or assembly issues. Are there differences depending on the version or size of the Hemnes dresser? Thank you for your insights and advice.
Hello adolf,
I assume you are mainly interested in practical information directly related to the use and repair of the HEMNES chest of drawers.
Based on several repair cases and user reports, the following replacement parts have been identified as particularly important:
- Drawer slides/runners: These are often the reason why drawers stick or do not open and close properly. Frequent opening can cause wear or bending.
- Screws and fasteners: Especially the connecting fittings (such as cam locks or wooden dowels) can loosen or break, leading to instability.
- Handle recesses or handles: These can wear out or break under stress, especially with heavy use.
- Back panels and fixing materials: These often affect the structural stability, especially if the chest is moved frequently or heavily loaded.
For durability, I recommend ensuring proper assembly and using only original replacement parts, as variations often cause fitting issues.
If you need specific parts, the article numbers on the Ikea website are very helpful.
I would like to add to Jensson’s points, focusing mainly on the mechanical components.
What is especially important in the HEMNES series are the drawer slides. They are subject to heavy use and are absolutely central to the functionality of the chest of drawers. Often, the plastic guides become brittle over time or break, which makes moving the drawers difficult or even impossible.
Equally important are the connecting dowels and wooden joints. For example, if the chest of drawers is frequently moved or subjected to heavy loads, these connection points can loosen. This results in a wobbly piece of furniture and significantly reduces stability.
Handles should not be underestimated either, especially in older models where the material can sometimes become brittle over time.
My recommendation: Anyone who values durability should keep spare parts such as the slides, connectors, and handles on hand, particularly for frequently used models.
Jensson schrieb:
Drawer slides/tracks: They are often the reason why drawers stick or no longer open and close properly.I basically agree with that, but I would like to question whether the problem might also be due to the construction itself. In my opinion, weather or humidity damage is an underestimated cause why spare parts like handles or slides fail on HEMNES dressers.
The pine wood used can shrink or swell. This causes the drawers to no longer fit precisely, which in turn puts additional strain on the hardware. Jensson, or anyone else here, do you have experience with such effects?
Furthermore, it would be interesting to know if incorrect installation or overloading (e.g., too heavy contents in the drawers) leads to faster failure of spare parts. This can be avoided through proper use.
My suggestion would be to look for replacement parts that compensate for stresses caused by wood movement (e.g., more flexible drawer slides) when purchasing spare parts.
theo63 schrieb:
In my opinion, weather or humidity damage is often an underestimated reason why replacement parts like handles or drawer slides fail on HEMNES dressers.I agree with you. In more humid rooms, pine wood swells noticeably, which can cause tension in the mechanism. I would also add long-term material fatigue to that.
I also consider the following important:
- Replacing plastic or metal guides, which are often not recognized as wear parts in the system
- The back panels, which not only provide stability but can tear under load if attached to an uneven wall
When ordering replacement parts, it’s important to remember that the entire functional chain matters. A broken spare part only works properly if the surrounding parts are intact.
As a supplement: It is recommended to always tighten fastenings properly during assembly without damaging the material; this noticeably extends the lifespan.
