ᐅ Which spare parts are most commonly needed for IKEA BRIMNES furniture?
Created on: 29 Apr 2021 08:37
bijan
bijan
29 Apr 2021 08:37
I am currently using some IKEA Brimnes furniture and have noticed that certain replacement parts seem to be needed more often during everyday use. Since I want to keep the furniture functional for as long as possible, I would like to start a detailed discussion:
Which replacement parts for BRIMNES furniture—such as beds, dressers, or wardrobes—have you found to be the most commonly required? I am especially thinking of wear parts like fittings, screws, hinges, or drawer slides.
I am also interested in whether there are any components that are particularly prone to issues due to intensive use and if you have any tips for better maintenance or repair to prevent damage over the long term.
Thank you in advance for your insights and experiences!
praWarre69
29 Apr 2021 09:03
Hey bijan,
great question, because BRIMNES is really a widely used series and everyone eventually needs replacements.
In my experience, most people get annoyed with the drawer rollers – after a few years they often don’t glide smoothly anymore, and then the drawer drags or sticks. I think it’s worth investing in small replacement parts from the original supplier; you can often reorder individual rollers from Ikea at a reasonable price.
bijan schrieb:
I’m also interested if there are any construction-related components that tend to be particularly susceptible and need to be replaced more frequently with heavy use
This usually applies to the hinges, especially on the cabinet doors. They don’t break right away, but if they become loose or don’t close properly, it can be quite annoying. Easy fix: replace or adjust the door hinges – you can usually find the right spare parts at Ikea.
And don’t forget the small plastic stoppers or locking elements on the drawers – these can break easily, especially under heavy load.
So, to sum up: hinges, drawer rollers, and small parts like locks are the main wear items on BRIMNES. But hey, that’s typical for Ikea and can be quickly repaired with a bit of DIY effort! 😉
Ryder35
29 Apr 2021 09:14
I usually reorder drawer slides and hinges from BRIMNES. Screws are rarely lost, but plastic clips for the back panel often go missing as well.
LAURE-TA
29 Apr 2021 12:26
Hello bijan and all readers,
I would like to take a closer look at some common replacement parts for BRIMNES, especially in the context of everyday wear and tear:
- Drawer rollers: Usually made of plastic, these tend to wear out quickly under heavy load and humidity. This then affects the sliding performance and overall function.
- Door hinges: Often become loose or develop play, causing the doors to not close properly. It is important to regularly tighten or adjust them during maintenance before a full replacement becomes necessary.
- Screws and fasteners: Although sturdy, repeated assembly and disassembly (e.g., moves) can damage threads or cause screws to be lost. It is advisable to pay attention to the screw quality, as IKEA replacement screws are often more affordable.
- Plastic stoppers and end caps: These small parts tend to fall off easily, especially if drawers are overloaded or damaged.
A common mistake is overloading the furniture, which shortens the lifespan of these wear parts. Therefore, avoiding overloading and careful handling can reduce the need for replacements.
In summary, regular inspection and careful use help keep the need for replacement parts to a minimum. However, for BRIMNES, rollers, hinges, and small plastic components are definitely the most heavily used parts.
Golekau
30 Apr 2021 07:49
Great topic here! I really like that such an overview is being created 😀
I recently went looking for spare parts myself because the drawers of my BRIMNES dresser just weren’t sliding smoothly anymore. After replacing the rollers, everything moved like butter again! A really simple, affordable fix that makes the furniture feel like new.
What I also noticed: The plastic clips on the back panel break quite easily, especially when moving or rearranging the furniture. Since I’ve had to replace them several times, I would definitely put those at the top of the list of frequently needed parts.
So, if you have someone handy with DIY skills: replace worn rollers and hinges right away—you’ll love your furniture! It greatly extends its lifespan and saves a lot of frustration.
To you all: Have you ever had issues with so-called “invisible” parts that only become noticeable when something sticks or rattles? Looking forward to hearing your experiences!
