ᐅ Which spare parts for Ikea Hemnes are most commonly needed for replacement?
Created on: 20 Jun 2020 08:37
keosauHello everyone, I am currently looking into spare parts for Ikea Hemnes furniture, as I want to carry out some minor repairs. My question is: Which spare parts are most commonly replaced in the Hemnes series? I am especially interested in experiences with furniture such as Hemnes dressers, beds, and wardrobes, since I have often heard about wear and tear on certain mechanisms or components. Are there typical weak points to watch out for? I look forward to your detailed feedback, as the quality and durability of the furniture are important to me and I want to prepare accordingly.
Hello keosau, your question is very relevant and touches the core concerns of many Hemnes users. In my experience, the following spare parts are most commonly needed and reordered for the Hemnes series:
- Drawer slides: These are particularly prone to wear, especially the plastic or metal types, which tend to loosen over time with frequent opening and closing.
- Hardboard back panels: Especially on dressers and cabinets, these tend to crack or break relatively easily, particularly if the furniture is somewhat older.
- Screws and fasteners: Since the furniture is mostly self-assembly, screws or dowels can sometimes be lost or damaged during transport and assembly.
- Furniture feet or small floor protectors: These are relatively easy to damage, especially with frequent use or on uneven floors.
Typical weak points are the cabinet doors, where the hinges can become misaligned or wear out more easily over time. It is worth ordering the appropriate replacement hinges directly from Ikea. Additionally, the wooden strips on the drawer fronts can sometimes chip – in this case, replacing the front panel is usually the only solution.
If you are interested in a specific piece of furniture, feel free to let me know, and I can provide more detailed advice.
angel schrieb:
Drawer slides: These are particularly prone to wear, especially the plastic or metal versions Hello everyone! I completely agree with angel. In my case, the drawer slides of the Hemnes dresser gave out after a few years. 😔 It’s especially frustrating when the drawers suddenly start sticking! The good part is that Ikea provides replacement parts easily, and the installation isn’t that difficult.
Also, I wanted to add that I had to replace the handles after some time as well – this doesn’t affect function much, but it does make a noticeable difference in appearance.
So, my recommendation: If you have multiple Hemnes furniture pieces, it’s better to stock up on spare parts in advance. This will save you a lot of trouble in the long run! One more tip: Keep the assembly instructions handy, as they sometimes include useful notes on replacing parts.
Hello keosau and all other interested parties,
I would like to summarize the topic in a structured way, especially focusing on the most common problem areas and replacement parts for Ikea Hemnes furniture. My experience is based on extensive use and repairs of several Hemnes dressers and beds:
- Drawer slides: Clearly the main reason for repurchases. It is especially important to check whether the slide rails have metal or plastic rollers. Metal slides usually last longer. Replacements are available directly from Ikea, but you should make sure the new slides match the production year of your model.
- Furniture feet and small floor protectors: Since Hemnes furniture is relatively heavy, the floor protectors often wear out quickly. Replacement parts are easy to obtain and are usually made of rubber or plastic.
- Screws and connectors: These parts lose stability with assembly errors or repeated disassembly. I recommend buying a screw set specifically designed for Hemnes when ordering replacements.
- Hinges: The fittings on doors often loosen over time. If the doors stick, replacing the hinges can work wonders. It is important to pay attention to the correct hinge type when replacing, as Ikea offers different versions.
- Wooden back panels: These are relatively thin and tend to crack under heavy load, so replacement is often necessary.
One last tip: Before ordering replacement parts, carefully check the exact model and the assembly instructions, as the same parts can differ depending on the production year. Otherwise, you risk buying the wrong parts.
I hope this helps you with your planning and brings you long-lasting enjoyment with your Ikea Hemnes furniture!
