ᐅ Which replacement parts are most commonly needed for the Ikea PLATSA system?
Created on: 25 Mar 2021 13:07
FRABEHello everyone,
I recently assembled a PLATSA wardrobe from Ikea and noticed that some spare parts are needed after only a short time. I am interested to know: Which spare parts are most commonly required for the Ikea PLATSA system?
I am not only referring to the obvious parts like screws or panels but also specific fittings, hinges, or other components that tend to be more vulnerable or need to be replaced more frequently based on experience.
For those who also use this wardrobe: Have you ordered certain spare parts multiple times or are you aware of typical weak points? I would like to know what to pay special attention to during assembly or later use to avoid issues.
Looking forward to your experiences and advice!
Hello FRABE,
I can help you based on my experience, as I have several PLATSA systems and have already ordered some spare parts. Generally, the parts that undergo the most mechanical stress need to be replaced more often. These mainly include:
- Hinges, especially those with a soft-close function, which can lose damping over time or become stiff.
- Drawer runners/slides, which wear out or become misaligned with frequent opening and closing.
- Plastic stoppers and drawer stops, which can break if drawers are handled too abruptly.
- Fasteners such as corner brackets or cam locks, which can get damaged with frequent assembly and disassembly.
I would recommend having these spare parts on hand if you plan to carry out minor repairs yourself. It’s also a good idea to have the appropriate shelves ready in case something becomes heavily loaded and sags.
In short: Mechanical parts that move are the ones most likely to need replacement. Ignoring this can lead to consecutive breakages, which I would advise avoiding.
If you’re unsure about any specific terms, I’m happy to help with explanations!
renpeo schrieb:
- Hinges, especially those with a soft-close function, which can lose damping over time or start sticking.This is an important point. I have put together a brief overview of the most common spare parts often needed for PLATSA, along with tips on what to watch out for when replacing them:
1. Hinges with Soft-Close:
- These are more complex and can stick or fail to close properly if the damping components become dirty or worn. Careful cleaning and adjustment often help, but after 2-3 years, replacement is usually recommended.
2. Metal and Plastic Connectors:
- During assembly or disassembly, cam connectors or small metal brackets can easily bend or break. These can be ordered individually and are inexpensive.
3. Slides and Runners:
- Drawers and pull-outs may have issues if they are not regularly lubricated or if overloaded.
4. Shelf Supports and Shelves:
- Excessive weight can cause shelves to sag or deform. Replacement shelves or additional supports can help.
Here are some practical tips for handling spare parts:
- Always check if adjustment is possible before removing parts.
- It’s best to order spare parts immediately when a part is damaged, as some components can sell out quickly.
- Keep instruction manuals and note the part names to avoid confusion.
If you like, I can also prepare a list of the most common spare part numbers for you. Just let me know!
Soft-close hinges are the most common to fail. They usually need replacement after a few years.
Also typical are the small plastic stoppers, which tend to break easily.
For everyday use, I recommend keeping a collection of screws and a spare set of cam connectors on hand. That’s all you need.
