ᐅ Which spare parts for Malm beds are most commonly defective?
Created on: 4 Apr 2024 19:17
Elisha65
Elisha65
4 Apr 2024 19:17
Hello everyone, I am currently working on the maintenance and possible repair of IKEA Malm beds. I have noticed that replacement parts are sometimes needed, but so far I have found little information about which spare parts for Malm beds are most commonly defective or need to be replaced. I am especially interested in whether there are typical weak points – for example, in the area of drawer slides, connector fittings, slatted frame fasteners, or other components that might cause problems more frequently.
Are there any people here with practical experience or professional background who can tell me which replacement parts for Malm beds tend to wear out or break regularly? And perhaps also if there are any tips for preventive measures? Thanks in advance for your insights and suggestions!
mauka
4 Apr 2024 19:45
Elisha65 schrieb:
I'm especially interested in whether there are typical weak points – for example in the drawer slides, connector fittings, slatted frame attachments, or other components that might cause problems more often.
Hey Elisha65! From my experience with Malm beds, the drawer slides are definitely the most problematic parts – the rails and rollers tend to break or become stiff under heavy use. This usually results from a combination of material fatigue and accumulated dust or dirt.
Otherwise, the connector fittings generally hold up well, but with heavy slatted frames or frequent disassembly, the attachments can sometimes give way. So my advice is to clean and lightly lubricate the drawers regularly; that will help you avoid a lot of trouble. A little maintenance goes a long way ;-)
BOMILAN
4 Apr 2024 20:11
Drawer slides and screws/fasteners often come loose. Most repairs involve precisely these components. Damage to slatted bed bases is usually due to bent slats or broken plastic holders.
U
usbla
5 Apr 2024 08:42
mauka schrieb:
Drawer slides really are the diva among the parts
That is correct. According to various forums and repair reports, the metal drawer slides on the Malm bed tend to wear out, especially the plastic rollers.
Additionally, it is common for the metal tabs connecting the side panels to bend or break due to constant stress. This significantly affects the stability.
The slatted frame is usually less affected by stress, but the plastic holders – as also mentioned by BOMILAN – are weak points that can crack under excessive load.
To prevent issues, it is recommended to regularly check the screws and tighten them if necessary, as well as avoid overloading, especially the drawers.
benon
5 Apr 2024 10:05
Hello Elisha65 and everyone else,
I would like to add that for Malm beds, the connecting materials such as dowels and screws often cause problems. Especially when the bed is assembled and disassembled frequently, these can loosen or break.
Furthermore, I have noticed that the drawer slides not only wear out mechanically but can also be affected by rust on the tracks if the beds are placed in somewhat damp environments. Simple maintenance by keeping them dry can help in this case.
If you have Malm beds that are used frequently, it is worth regularly checking the fasteners and replacing them in time to avoid more serious damage.
Davidleo
5 Apr 2024 14:12
benon schrieb:
If you have Malm beds with frequent use, it’s worth regularly checking the fasteners and replacing them in time to prevent major damage.
Absolutely correct! I’ve had my bed for 3 years, and for me it was actually the drawer rollers that eventually became very stiff and started squeaking. After replacing them, everything works perfectly again! It’s really amazing how much replacing small parts can improve things 🙂
A little maintenance, and the bed lasts forever – it’s definitely worth it!
