ᐅ Which small components are especially important in the Ikea Metod kitchen system?
Created on: 8 Dec 2020 08:42
danke37Hello everyone, I am currently planning a larger kitchen project using the Ikea Metod system and am focusing intensively on the many small components needed for assembly and daily use. I have noticed that some of the smaller parts, which may seem insignificant at first glance, can actually have a big impact on stability, ease of installation, or everyday functionality. Therefore, I would like to ask: Which small components in the Ikea Metod system do you consider particularly important or even essential? Specifically, I mean parts like special connectors, dampers, hinges, trims, or mounting screws that are small but make a significant difference. I would be very grateful if you could share your experiences and opinions— the more detailed, the better—so I don’t miss anything important when ordering or assembling.
Cecilera668 Dec 2020 09:47Hello, the most important small part in Metod is definitely the Hettich clip used for mounting the hinges. Without it, nothing works. Also, I would pay attention to mechanical dampers on drawers and doors, as they protect the material and ensure long durability. You should only use the original screws.
Hello danke37,
I’m happy to give you a comprehensive overview of what I consider the most important small components in Ikea Metod:
- The hinges are crucial, especially those with integrated soft-close functionality, as they not only protect the doors but also provide a high-quality user experience.
- Fastening elements like the tension clamp are essential to hold the cabinets securely and cleanly together. Without them, stability can be compromised.
- Covers and trims help to conceal screw holes and create a visually consistent appearance.
- Screws and dowels are often underestimated – with Metod they need to fit precisely to avoid damaging the material.
If you like, I can also give you tips on assembly to make the most of these small parts. Especially with the system’s complexity, care is required, but don’t worry – it’s definitely manageable!
Hello danke37,
I would like to add some technical details here that are often overlooked but essential for achieving a high-quality result with Metod:
First, the connectors such as cam lock screws (dowel rails and connector fittings) are absolutely critical for the frame stability of the base cabinets. Most issues during later use occur when these small components are installed incorrectly or are of poor quality.
Second, the soft-close dampers on drawers and doors are not just comfort features—they significantly extend the lifespan of the kitchen fronts by eliminating impact noise and reducing mechanical stress.
Third, the mounting brackets and fastening clips should be carefully positioned, as they ensure precise alignment, which is particularly important for weight distribution and safety with large wall cabinets.
Finally, a note: pay attention to the correct screw types (pan head, countersunk) and lengths, as there are subtle differences in load capacity. If you like, you can describe your planned kitchen size and cabinet types, and I can provide more specific advice regarding the combination of small fittings.
reoleon479 Dec 2020 12:03Hey danke37, very interesting question! I love the Metod system and can only confirm what has already been said. The dampers make a huge difference – they significantly soften the closing of the doors, which keeps the kitchen looking new longer and also gives it a high-end feel 🙂
Exactly! And don’t forget the clip-on hinges! They are very convenient for installation and removal and make assembly much easier.
My recommendation: don’t save money on small parts and buy everything as original as possible! Good luck with your kitchen planning – you’ve got this!
Cecilera66 schrieb:
Also, I would pay attention to mechanical dampers on drawers and doors, as they protect the materials and ensure a long lifespan.
