ᐅ What adjustments can help if Malm drawers stick or jam?
Created on: 4 Dec 2022 09:37
Anjama
Anjama
4 Dec 2022 09:37
I have an issue with my IKEA Malm dressers – specifically, the drawers stick or catch when opening or closing. It feels like the drawers are not properly aligned or the sliding rails are adjusted too tightly. My question is: What adjustments to the drawer slides or other components of the Malm drawers are effective if the drawers stick or are difficult to move? Are there useful fine-tuning options to look out for to ensure smooth, jerk-free movement? I would like to know if it’s possible to make adjustments without fully removing the drawer, and what tricks have proven to fix the problem permanently.
I’m looking forward to your tips and experiences!
Repar
4 Dec 2022 10:02
Basically, you should first fully pull out the drawer and clean the guide rails. Dust and dirt are often the cause of sticking.
Then check if the rails are properly aligned. With Malm drawers, the guide rails are usually attached with small screws – you can easily adjust these.
Tightening or loosening the screws can also help to prevent the drawer from running too tightly.
SauDietmar
5 Dec 2022 14:19
Hello Anjama,
Your issue is quite common with Malm drawers and can usually be resolved well if approached systematically. I recommend the following steps:
1. Remove the drawer completely: Pull the drawer out fully and lift it slightly to detach it from the runners. This allows you to inspect it more easily.
2. Check the guide rails: The metal or plastic rails that the drawer runs on should neither be bent nor dirty. Use a soft cloth and, if necessary, a mild cleaning agent to remove dust and debris.
3. Inspect the screws: On Malm dressers, the rails are attached with small screws. If a screw is loose, the drawer may stick. Tighten any loose screws as needed.
4. Adjust drawer alignment: Usually, there are small adjustment screws or plastic inserts on the sides of the drawer that allow horizontal and vertical alignment. Carefully adjust these so the drawer runs parallel to the side walls without any rubbing.
5. Apply lubricant: Once everything is clean and adjusted, a furniture-specific glide spray or solid silicone lubricant can significantly improve smooth operation. Be sure not to use oil as it attracts dust and worsens sliding.
In summary:
Repar schrieb:
Clean the guide rails and readjust the screws
is important, but without setting the alignment, this doesn’t always solve all problems. In my experience, also avoid overloading the drawer, as sustained heavy weight on the runners can cause premature wear.
I hope this helps you! 🙂
RETRAVIS
6 Dec 2022 18:45
For clarification: Malm drawers feature two types of guide rails – side-mounted full-extension rails and sometimes a traditional bottom rail for support. Depending on the model, the issue can be resolved in different ways.
It is important that the system is completely intact: check for any deformations or broken plastic parts on the teeth of the rails. Such defects often cause sticking.
SauDietmar schrieb:
Silicone lubricants improve smooth operation
This statement is absolutely correct. However, please use only special furniture lubricants, as other lubricants like WD-40 can damage the material or attract dust.
Repar schrieb:
Tightening screws to correctly align the rail
This is primarily the key to the solution. However, make sure to test the drawer’s movement after each adjustment, as too much tension can also lead to sticking.
In summary, I recommend:
- Cleaning and inspecting all rails and screws
- Adjusting the rails
- Using an appropriate lubricant
- Regularly checking and carefully observing the maximum weight allowed in the drawer
With these steps, a Malm drawer will run smoothly again.
