Hello everyone, I am planning to assemble an IKEA Platsa shelving system and would like to use higher-quality screws instead of the ones provided. My question is: which screws work best for IKEA PLATSA in terms of stability, ease of assembly, and long-term durability? I am particularly interested in the type and material of the screws, their length and diameter, as well as suitable screw types that match the supplied engineered wood materials without causing damage. It would also be helpful if someone could explain any special recommendations, for example when working with particleboard or MDF, which are often used in PLATSA models. Thank you in advance for your expert advice and experiences!
The most suitable screws for IKEA PLATSA are generally wood screws with a countersunk head, sized between 4 and 4.5 mm in diameter and 40 to 50 mm (1.6 to 2 inches) in length. These dimensions provide sufficient holding force and prevent the material from splitting.
Since PLATSA components are often made of MDF or particleboard, I recommend screws with coarse threads to achieve better grip in the engineered wood. Stainless steel or galvanized screws are also corrosion-resistant and durable. During assembly, it is advisable to use a torque limiter to prevent over-tightening and cracking.
I would like to provide a brief overview that should be helpful:
- Beginner: Wood screws 4x40 mm (4x1.6 inches), galvanized, with coarse threads. Good price-performance ratio.
- Mid-range: Stainless steel A2 countersunk screws 4.5x45 mm (4.5x1.8 inches), ideal for higher moisture levels or greater stress.
- Professional: Chipboard screws with partial thread, 4.5x50 mm (4.5x2 inches), especially suitable for MDF to prevent splitting.
It is important to drill a pilot hole of about 3 mm (1/8 inch) before screwing to protect the material. I recommend not placing screws directly into the carcass, but always in the area of the braces. Otherwise, there is a risk of breakage.
Summary: Quality comes first – stainless steel chipboard screws with good threads and appropriate length offer the best combination of strength and durability.
