ᐅ Which screws must not be swapped during the assembly of Ikea BESTA?
Created on: 9 Aug 2021 14:22
gilida
gilida
9 Aug 2021 14:22
Hello everyone, I am currently assembling the IKEA BESTÅ system and have a specific question regarding the screws and connectors:
Which screws must never be swapped during the assembly of IKEA BESTÅ, meaning which types are absolutely position-specific and could seriously affect the stability or functionality of the furniture if used incorrectly?
I would greatly appreciate detailed advice on exactly where each screw must be used correctly – for example, dowels, special screws of different lengths, or connector screws for cabinets or drawers.
I have tried to follow the instructions carefully, but some screws look very similar, and I want to avoid having to disassemble everything or ending up with unstable furniture.
Fitigu
9 Aug 2021 14:47
Basically, the BESTÅ system is designed so that every screw and connector has a clearly defined place. The most important screws that must not be confused are:
- The long wood screws that connect the back panel profile to the side panels. If these are mistakenly replaced with shorter screws, the back panel can come loose and the overall stability will suffer.
- The cam lock fittings (also called Minifix), which connect the side panels to the carcass boards. It is crucial that the cam lock screws are not swapped with regular screws, as the connection will not tighten properly otherwise.
- Special dowel or bolt screws that often require a metal insert in the side panel. These screws differ in thread and length, so mixing them up results in poor connections and a twisted carcass.
I recommend sorting the screw packages before assembly and carefully following the installation instructions. Also, visually checking the screw types against the drawings in the manual helps. When all screws are used according to the instructions, everything fits together securely.
PAR63
9 Aug 2021 15:02
Fitigu schrieb:
The cam connectors (also called Minifix), which join the side panels to the carcass boards. It is crucial not to confuse the cam screws with regular screws, as the latter cannot tighten the connection properly.
Exactly, I would like to add some notes about common mistakes when assembling BESTÅ:
- Cam screws must always be used in their designated positions, as their thread and head size are matched to the connector parts.
- The smaller screws used for attaching the back panel or trims can differ only slightly from other screws (in length and thickness). They should not be swapped, as this can damage the wood panel hole or cause the screw to not hold.
- The long screws with wing nuts for attaching connector feet are often mistaken for regular wood screws. This especially causes instability in the base feet.
In summary: Screws for cam connections, back panel screws, and base foot fastenings must not be interchanged at their respective positions. Good preparation, such as sorting and comparing with the manual, is very valuable here.
besau
9 Aug 2021 21:39
With BESTÅ, it is especially important not to confuse the cam screws with the long side screws. Otherwise, the cabinet will become unstable. The other screws are usually more forgiving, but be sure to follow the instructions carefully.
laureo
10 Aug 2021 08:17
gilida schrieb:
Which screws absolutely must not be mixed up during the assembly of IKEA BESTÅ, meaning which types are strictly position-specific and could seriously affect the stability or functionality of the furniture if used incorrectly?
This is an important point you raise. Mixing up the screws in BESTÅ can significantly impair its function. For example:
- The connecting screws for the drawer slides are very precisely sized. If swapped, this can cause jamming or looseness.
- Specialized threaded screws are often used for the feet. Using the wrong screws can lead to wobbling.
- The screws for the back panel strips must also be used in the correct position; otherwise, the back panel can become unstable.
In practice, it helps to double-check the length and thread of screws before assembly when they look similar. Repeatedly verifying prior to screwing in can prevent problems later on.
