ᐅ Which screws provide the most durable assembly for IKEA BESTA units?
Created on: 13 Jun 2019 08:47
blafar52
blafar52
13 Jun 2019 08:47
I am currently working on assembling my new IKEA Besta system and want to optimize the durability of the construction as much as possible. I have a question: What type of screws provide the strongest and most long-lasting connection when assembling IKEA Besta?
Specifically, I am interested in factors such as material quality, thread type, length, and diameter of the screws. Should the original screws be replaced or supplemented with other types to improve stability? Are there any experiences with particular screw types that perform better than the ones supplied?
Additionally, any tips on how to properly tighten the screws to avoid damage to the materials while still achieving a secure and durable connection would be helpful.
I appreciate any recommendations and experiences, as I want to find the most durable solution that won’t become loose or unstable after a short time.
TARAON
13 Jun 2019 09:21
blafar52 schrieb:
Which type of screws provides the strongest and most durable connection when assembling IKEA BESTA?
Hey! Great question – I know how frustrating it is when a piece of furniture doesn’t hold together as well as you’d like. 😊
Basically, the screws IKEA provides are not bad at all; they’re optimized for the system. However, in my experience, using slightly longer screws with a larger diameter in the load-bearing parts adds more stability – especially when stacking the modules on top of each other.
In terms of material, galvanized screws offer better corrosion resistance, which is definitely a plus if the furniture comes into contact with damp hands or is used in kitchen environments.
Regarding the thread type: fine threads provide a strong grip in wood unless the material is very soft. In that case, coarse threads work better to anchor screws securely in particleboard.
So, in short: slightly longer, galvanized particleboard screws with coarse threads are often my go-to recommendation! 😉 Just be careful not to overtighten.
NOAHSAU
13 Jun 2019 10:03
blafar52 schrieb:
Should one maybe replace or supplement the original screws with different types to improve stability?
In my opinion, it's best to discard the supplied screws right away and opt for proper quality hardware instead. These IKEA screws tend to be rather weak and often just average.
If you want the BESTA system to remain secure over time, you should consider high-quality stainless steel or carbon steel screws. These are not only stronger but also corrosion-resistant. The correct length is crucial—too short screws won’t hold at all, while too long ones can split the material.
Also, Teflon-coated or black phosphate screws tend to resist loosening in tight joints—so be careful if you plan to disassemble or modify the furniture in the future.
My two cents: it’s better to invest now for peace of mind with your furniture. Those who stick to the original screws risk the first wobble after 1-2 years.
Gerard
13 Jun 2019 11:17
Regarding the discussion about screws for IKEA BESTA:
- Most IKEA furniture, including the BESTA system, is made from particleboard. For such materials, coarse-thread particleboard screws are best suited because they grip the engineered wood better.
- Zinc-plated screws prevent rust and are more durable in typical indoor environments.
- In many cases, using slightly longer screws (at least 4-5 mm longer than the original screws) improves joint stability.
- It is also important not to overtighten the screws, as this can damage the material and cause the screw to lose its hold.
- Alternative screws made of stainless steel offer advantages especially in damp areas, but their diameter should match the drilled hole.
Recommendation: Instead of using basic standard screws, it is better to invest in high-quality coarse-thread particleboard screws made of zinc-plated steel that are about 4 mm longer than the originals.
Juansi50
13 Jun 2019 11:49
I used standard zinc-plated chipboard screws, 4x50 mm (4x2 inches), for my BESTA furniture. They are sturdy and hold significantly better than the original IKEA screws. Important: Drill pilot holes carefully to avoid splitting the chipboard.
Peone
13 Jun 2019 14:28
Hello blafar52,
Your question is very good and shows that you are thinking about quality and stability.
Regarding the screws: The screws supplied by IKEA are usually basic standard ones to keep costs low. This means they are functional but not ideal for long-term load, especially if you plan to frequently rearrange the modules.
If you want to improve stability, I recommend the following approach:
- Use galvanized chipboard screws with coarse threads, in a length that securely penetrates deep enough into the wood without going all the way through.
- Be careful not to overtighten the screws to avoid damaging the chipboard.
- For additional reinforcement, you can also use cam lock or connector screws, which hold the system together with more pressure.
- If possible, use common dowels and matching screws to strengthen the connections.
For tightening: It is best to work carefully using a torque wrench or a cordless drill with torque control. Otherwise, the furniture may suffer!
If you like, I can gladly provide recommended screw brands and sources.
