ᐅ Which screws do you use when a BILLY shelf needs to support heavy loads?
Created on: 31 Dec 2016 10:17
minidraHello everyone,
I have a rather technical question and hope to benefit from your experience: Which screws do you use when you need to ensure serious load-bearing capacity for an IKEA BILLY shelf?
I’m not talking about the standard load capacity for books, but situations where the shelf is subjected to significantly heavier loads, for example due to especially heavy items or if the shelf has to be mounted in sensitive areas.
I’m mainly interested in a type of screw that is mechanically stronger than the original furniture screws—both in terms of material thickness and thread quality.
Are there any recommendations for specific screw types, perhaps with tips on pre-drilling, screw length, or diameter?
Thanks in advance for your help!
minidra schrieb:
Which screws do you use when you want to ensure a serious load capacity for an IKEA BILLY shelf?Hello minidra,
your question is very precise, which makes it easy to address. Basically, I recommend using galvanized or stainless steel chipboard screws instead of the original furniture screws, which are often made of soft steel. Screws with a full thread are ideal because they grip the material better.
For a heavily loaded BILLY shelf, I would use screws with at least 4mm diameter (about 5/32 inch), preferably 5mm (about 3/16 inch), and a length of 50–60mm (2–2.4 inches). It is important to pre-drill the holes where you want to insert the screws to avoid splitting the wood and to ensure the screws sit evenly.
If the shelf will bear an extremely heavy load, it is also worth using metal brackets to reinforce the corners, which can be fastened with screws.
If you have any further questions, just let me know!
Ulrichta schrieb:
For a heavily loaded BILLY shelf, I would use screws with at least a 4mm diameter, preferably 5mm, and a length of 50-60mm (2-2.4 inches).To elaborate further: BILLY shelves are mainly made of particleboard. The main weak points under heavy load are often the edges and joints of the shelf components.
I recommend using screws with a somewhat coarse thread, so-called SPAX-quality screws, as they are optimized for wood and particleboard applications. Make sure not to use screws that are too short – 60mm (2.4 inches) is quite good for a firm hold, but depending on the shelf thickness, 70mm (2.8 inches) can also make sense.
Important: always drill a pilot hole before screwing in. This prevents cracking in the particleboard and ensures better durability. The pilot hole should be 70-80% of the screw diameter.
Alternatively, you can attach metal reinforcement brackets (angle braces) to the back panel, which distributes the load much better and means the screws don’t have to bear all the pressure alone.
One more note: for heavily loaded systems, it’s better to avoid particleboard dowels, as they sometimes tear out under high stress. Screws with a full thread are generally more stable.
Have you considered replacing the back panel with a thick plywood board? This can greatly improve load capacity – admittedly, it’s a more involved modification.
Rashadmeo1 Jan 2017 09:14Lance schrieb:
I recommend using screws with a somewhat coarse thread, so-called SPAX quality materialOh yes, SPAX screws really rock! I recently reinforced my BILLY shelves with them because I use them in my workshop to hold heavy tools.
Honestly, they hold firmly! And if you combine them with a bit of construction adhesive, the whole thing is practically indestructible. 🙂
Even better: use countersunk screws so the screw sits flush and nothing catches. Pre-drilling is essential, otherwise the wood can split very quickly.
So – my recommendation: SPAX screws, 5x60 mm (0.2x2.4 inches), pre-drill, and add a bit of craftsmanship, and the BILLY shelf will hold some serious weight! 🙂
Rashadmeo schrieb:
So – my recommendation: SPAX screws 5x60 mm (5/16 x 2 3/8 inches), pre-drill and add a bit of craftsmanship, then the BILLY shelf can hold real heavy weights! 🙂Thanks for all your detailed advice! However, I’m still wondering if you have any alternative material or screw recommendations in case the shelf also needs to be anchored to the wall with anchors. Right now, my main focus is on the screws into the shelf wood itself, but a combination with a particularly secure wall fixing would, of course, be ideal.
My wall is standard concrete, not drywall. Is there a specific combination of anchors and screws that works well with the rather coarse screws used in the shelf structure? Or is it sufficient to use standard expansion anchors plus size 6 screws for the wall?
Looking forward to your experiences!
