ᐅ Which screws should I use to install IKEA Metod glass fronts?
Created on: 7 Mar 2022 09:17
Minkar
Minkar
7 Mar 2022 09:17
Hello everyone, I am currently planning the installation of IKEA Metod kitchen fronts with glass and am unsure which screws to use exactly. The IKEA instructions only provide general guidance, but especially for the glass fronts, the choice of the correct screw size and type seems very important to ensure stability on the one hand and to avoid damage to the glass on the other. Does anyone have experience with which screws are best suited? I am particularly interested in whether certain lengths, materials, or screw head types should be considered. If possible, a recommendation on the drill diameters to pre-drill would also be very helpful. Thanks in advance for the tips!
Katan
7 Mar 2022 11:23
Hey Minkar, that’s a great question, one I’ve wondered about myself several times! For the IKEA Metod glass fronts, I would recommend using countersunk screws – they sit flush and don’t press on the glass. Regarding the length, I usually go with 25mm (1 inch) screws to ensure enough grip in the cabinet but not so long that they risk damaging the glass. Standard galvanized screws are perfectly fine in terms of material. It’s also important to always pre-drill carefully before screwing in, so the glass isn’t stressed. Start with a very thin drill bit and gradually increase the size. This way, you avoid cracks. If you want, I can share some more tips on handling during installation 😉
jotisi
7 Mar 2022 14:02
Katan schrieb:
For the IKEA Metod glass fronts, I would recommend using countersunk screws – they sit flush and don’t press on the glass again.
I see this a bit differently. In my opinion, countersunk screws are not always the best choice for glass fronts because they can locally stress the material too much. I prefer pan head screws with a large bearing surface – they distribute the pressure better, which is especially important for thin glass. Regarding length, I tend to choose 30 mm (1.2 inches) screws, as screws hold better the more threads are embedded in the wood. However, it’s important to protect the glass with a gasket or at least a suitable spacer. I also advise against using simple galvanized screws – stainless steel is more durable and looks better in the long run.
anken
8 Mar 2022 07:48
I will add some technical input to the previous posts: When installing IKEA Metod glass fronts, you should choose screws that not only look appropriate but are also mechanically suitable. The fronts typically have a frame that holds the glass, so the screw should ideally engage with the frame rather than directly with the glass.
- Countersunk screws are common because they sit flush and do not create edges.
- The length should be selected to ensure a secure connection to the cabinet carcass, approximately 25-30 mm (1-1.2 inches).
- For the material, I recommend stainless steel to prevent corrosion in humid areas.
- Pre-drilling is essential to avoid splitting and should be done with a drill bit slightly smaller than the screw diameter.
A plastic spacer or washer can also be helpful to prevent pressure points. This way, you are on the safe side.
fikeo
9 Mar 2022 16:35
Hello Minkar, I have installed several Metod glass fronts myself and always use the following approach:
- Screws: I use stainless steel countersunk screws, 25 mm (1 inch) long. The stainless steel prevents rust and matches well with white or colored frames.
- Drilling: For preparing the fixings, I recommend pre-drilling with a 3 mm (1/8 inch) drill bit to avoid material breakage. After that, you can enlarge the hole with a 4 mm (5/32 inch) drill bit if the screw diameter is around 4 mm (5/32 inch).
- Protecting the glass: To prevent stress points on the glass, I place small rubber buffers or plastic washers around the screw, especially when the screw is close to the glass.
Make sure not to tighten the screw too much, as excessive pressure can cause the glass to crack. The installation isn’t particularly difficult, but with a bit of care, you will get a stable and secure result. If you like, I can also share my recommendations for drill types and torque settings.
