Hello everyone, I am currently planning to attach a few IKEA Billy shelves to an acoustic wall in the living room and am wondering which screws experts recommend for assembling this piece of furniture.
It is important to me that the screws ensure both stability and make the assembly process as smooth as possible.
Are there specific types of screws that are better suited than the original IKEA fasteners, especially for joining the shelf parts and possibly securing the shelves to the wall?
I would also appreciate hearing if anyone has experience with which screws are more durable or load-bearing in comparison, or if it is best to stick with the standard IKEA screws. Thanks in advance for your expertise!
For assembling Billy shelves, I strongly recommend using original wood screws with a screw diameter of 4 mm and a length of 30-40 mm (1.2-1.6 inches).
Additionally, appropriate wall plugs and screws should be used for wall mounting, depending on the wall type.
Metal screws are not necessary for connecting the shelves.
I’d like to go into a bit more detail here, as screws for a Billy shelf are used in several different applications:
1. Shelf connection (assembling the panels): The included Euro screws or wood screws like Spax are commonly used here. It’s important that the screws are not too thick, since the material is a 16mm (0.6 inch) particleboard, which is quite thin.
2. Wall mounting: It’s essential to choose anchors and screws suitable for the wall type (e.g., expansion anchors or heavy-duty anchors for concrete, or hollow wall anchors for drywall). The screws should be at least 6-8mm (1/4–5/16 inch) in diameter and about 50-70mm (2–2 3/4 inches) long to hold securely.
3. Alternative screws: For greater stability, you can opt for galvanized Spax screws or specially coated wood screws.
A quick tip: When assembling the shelf parts, avoid pre-drilling too aggressively or being overly cautious, as this can cause the particleboard to split. Also, regularly checking the screw connections after a few weeks increases safety.
Feel free to share whether you just want to place the shelves freely or if you plan to load them and securely fix them to the wall. This significantly affects the choice of screws.
An interesting point from Domau0 is the material itself – particleboard – which is often underestimated. The standard IKEA screws are practical in that they are designed specifically for this material and construction, but in terms of durability or load capacity, better screws can definitely be superior.
This is exactly the key issue: Choosing the “best” screws for the shelf is not enough if the wall fixing is weak.
Therefore, when securing something to the wall, you should always consider an overall concept: suitable anchors, screws, and the correct tools for the type of wall. Cutting corners here risks damage or accidents.
Domau0 schrieb:
2. Fixing to the wall: You should definitely choose anchors and screws that are appropriate for the wall
In summary, based on my experience and research, the following can be said:
For connecting the individual Billy panels, the original IKEA wood screws are completely sufficient. These typically have a diameter of about 4 mm (0.16 inches) and are specifically designed for chipboard materials. The design of these screws ensures that the material is not overly stressed and that the connection remains permanently stable.
For wall mounting, it is essential to choose screws and anchors suitable for the type of wall.
- For concrete or brick walls: expansion anchors with 6-8 mm (0.24-0.31 inches) screws, approximately 60 mm (2.4 inches) in length.
- For drywall (plasterboard) walls: cavity anchors with appropriate screws.
It is also important not to use screws that are too long or too thick to avoid damaging the shelf or overloading the wall.
A good quality recommendation for screws are zinc-plated chipboard screws with countersunk heads. These provide good grip and corrosion protection.
If a higher load capacity is desired, high-quality stainless steel screws are an alternative, offering better corrosion resistance.
If there are further questions regarding the wall type or load, I can provide more targeted advice.
Thank you very much for the detailed responses so far. Regarding wall mounting: my wall is a solid brick wall, not drywall.
My goal is to secure the shelves firmly and stably to the wall, as they need to support a certain weight of books.
Which brands of anchors or types of screws would you recommend for this application? And what about the length? Longer screws would provide more holding power but could also damage the panels. What is your advice on finding an optimal balance?
Also, I am interested to know if there is a specific brand that you would particularly recommend for the wood screws used in the shelf construction itself, or if the original IKEA screws work well enough.
Lucien schrieb:
For concrete or brick walls: expansion anchors with 6-8 mm (0.24-0.31 inch) screws, length about 60 mm (2.4 inches)
