I am currently planning to reinforce my Billy shelves to make them more robust and suitable for heavier loads. This raises the question for me: which screws are the strongest and best suited for assembling and strengthening IKEA Billy shelves?
I have found various recommendations online, but the information regarding material, length, diameter, and thread type varies widely. In particular, I am interested in whether it’s better to replace the original screws with stronger wood screws, particleboard screws, or perhaps even machine screws.
The length also plays a role – is the standard length sufficient, or should longer screws be used to achieve better durability?
It is important to me that the screws are compatible with the material of the Billy shelves (mostly particleboard) without damaging it, while still providing the highest possible load-bearing capacity.
I look forward to well-founded advice and experiences on this topic.
Basically, I do not recommend using standard, very thin insert nuts or short screws for Billy bookcases, as the particle board tends to break easily.
The best option is particle board screws with a diameter of at least 4 mm (0.16 inches) and a length of about 40-50 mm (1.6-2.0 inches). These provide good hold without excessively weakening the material.
For most applications, particle board screws are preferable, as they are specifically designed for this material, unlike machine screws, which require threading in metal or pre-installed nuts.
If you want to reinforce the shelves further, it might be useful to add metal brackets, but that is a separate topic.
Fopizar schrieb:
"whether it is better to use stronger wood screws, particle board screws, or possibly even machine screws instead of the original screws supplied"
As an addition:
There are also partially threaded screws, which are especially advantageous for wood-based materials like particleboard because the smooth section just after the threads provides better clamping.
When purchasing screws, you should look for galvanized versions to prevent rusting, especially if they might be stored in damp conditions.
It is also important to use screws with a suitable Phillips or Torx drive, as these tend to be less damaged and transmit torque better.
mo-hau schrieb:I agree and would add that a length of 50 mm (2 inches) is usually a good compromise; longer screws often don’t offer any advantage for thin shelf sides.
"Particleboard screws with a diameter of at least 4 mm (0.16 inches) and a length of about 40-50 mm (1.6-2 inches)"
Hello, I have spent a long time considering this myself because I wanted to reinforce my Billy shelves due to heavy books.
One problem is that the chipboard used in Billy shelves is relatively thin – screws that are too thick can split the material. From my own experience, I can only recommend paying attention to the quality of the screws, not just their size. Cheap screws tend to break more often or have poor thread pitch.
That sums it up exactly. I used fine-thread screws because they grip better. However, I also reinforced some shelves with small metal brackets – that adds even more stability.
I understand it’s a balancing act between screw length, diameter, and protecting the material. Maybe try testing on a scrap piece to see which screw holds best without causing damage.
Fopizar schrieb:
"It is important to me that the screws are compatible with the Billy shelf material without damaging it"
For Billy shelves, I recommend 4x40 mm (4x1.6 inches) galvanized chipboard screws with a Phillips head.
Machine screws are rarely suitable here since you don’t have metal threads or matching nuts.
If you want more stability, increase the number of screws or add metal brackets.
