ᐅ Which screws are especially durable for Ikea Platsa units?
Created on: 13 Sep 2020 08:37
jimmy63
I am currently considering the Ikea Platsa cabinet system and looking closely at the screws used. My question to the community is specifically: Which screws in the Ikea Platsa system are particularly durable and resistant, especially if the furniture is frequently reassembled or subjected to heavy use?
I am mainly interested in the types of screws (e.g., wood screws, cam locks, dowels), their quality compared to similar products, and any potential weak points that could quickly cause problems in everyday use. Has anyone had experience with which screws can be used without concern and for which models or screw types it might be better to take precautions, such as having replacements on hand or using stronger alternatives?
I would appreciate concrete tips and experiences so that I am well prepared before purchase and assembly. Thank you in advance for your feedback!
Samuel
14 Sep 2020 14:53
Hey everyone,
I just wanted to quickly mention how pretty cool it is that Ikea's Platsa system has made assembly easier for me. Screws aside – yes, a bit of extra effort for higher-quality replacement screws makes sense if you plan to rebuild it more often.
You should also remember that many screws in the Platsa series are designed for a standard service life. If you reassemble the furniture in a new home, you might notice that the screws in the wood don’t hold as tightly anymore. Then it’s just a matter of tightening or replacing them.
Here’s a tip: use a torque wrench or regularly check the tightness to avoid surprises.
In the end: the original screws are fine, but for long-term users, better screws are definitely a smart choice!
FAZAR
15 Sep 2020 09:16
jimmy63 schrieb:
I assume some wear and tear is normal, but I would prefer not to have to buy new screws every 1-2 years or have the parts become unstable.
Thank you for your additional information about the frequency of use.
Since you rebuild the furniture about 1-2 times per year and also plan for moderate loads, I technically recommend using alloy steel screws with a slightly larger diameter (e.g., 4 mm (0.16 inches) instead of 3.5 mm (0.14 inches)), combined with appropriate wall anchors or plugs for the load-bearing elements.
It is also important to tighten the screws evenly and without overtightening during assembly to protect the material around the screw seat. For cam lock fasteners, it’s advisable to regularly check for a secure fit and, if necessary, apply a drop of medium-strength threadlocker to prevent loosening.
This approach ensures that the construction remains stable even with regular rebuilding and that you don’t frequently need replacement parts.
If you are interested, I can prepare a list of screw types and suitable sizes for the Platsa modules.
