ᐅ Which screws are most commonly forgotten when assembling IKEA PLATSA?
Created on: 18 Mar 2022 08:17
Targu
Hello everyone, I recently assembled an IKEA Platsa wardrobe and noticed that I seemed to be missing several screws, which significantly delayed the assembly. I would like to know: Which screws are most commonly forgotten or overlooked during the IKEA Platsa assembly? Are there specific parts or fasteners that you should pay special attention to in order to avoid unexpected interruptions during the build? I would appreciate your experiences and tips!
Palenar
18 Mar 2022 12:45
Good method from baupau! Additionally, I would like to add: When sorting, it’s worth carefully checking the screws by length and diameter. In the assembly kit, there are screws that look very similar but are intended for completely different joints. Mixing these up can, for example, cause the back panel to be unstable or lead to pressure marks forming in the end.
The cam locks and dowels also vary not only in size but sometimes in length – it’s best to cross-check them in the manual’s parts lists rather than just sorting by eye.
Finally: If the cabinet will be used for heavy loads, make sure to use the long plastic dowels included. These are sometimes overlooked because, unlike the other screws, they are packaged separately in small bags. I hope this helps for as error-free a planning process as possible.
Farmo
18 Mar 2022 13:15
One more tip: Screws for the floors (including small, round ones) are often not counted accurately. Double-check them before installation.
Daledra
18 Mar 2022 13:40
In addition to the mechanical screws, the small plastic pin that acts as a spacer is often overlooked. It is important for aligning the doors.
Elias
19 Mar 2022 08:12
Palenar schrieb:
PLATSA includes screws that look very similar but are designed for completely different connections.
That sounds really important! Unfortunately, I once used the "wrong" screw and had to take everything apart again. Now I'm worried it might happen again. How do you handle this technically? Do you always measure precisely or just rely on the pictures in the manual?
Palenar
19 Mar 2022 08:45
Elias schrieb:
How do you handle this technically? Always measure precisely or just rely on the pictures in the manual?
I always recommend measuring the screws with a caliper or at least a ruler, as a difference of 1-2 mm (0.04-0.08 inches) can be crucial. The visual cues in the manual are helpful but often not enough to be completely certain. Especially the cam locks come in different sizes, and a mistake here can make assembly more difficult later on.
jordanvin
19 Mar 2022 10:20
Wow, so many details – great! Maybe IKEA should really include a dedicated screw guide for PLATSA so you can check everything properly beforehand. It’s more fun when everything fits right away!
Don’t get discouraged, everyone – PLATSA can really deliver!
