ᐅ Which fasteners are included in the IKEA Brimnes assembly kit?
Created on: 27 Sep 2020 09:23
V
vinkin
Hello everyone, I have a specific question about the IKEA Brimnes assembly kit: Which fasteners—that is, the exact types and sizes of screws, wall plugs, and similar connectors—are typically included in this set? I am interested not only in the quantities but also in the precise types, such as wood screws, particleboard screws, or other specialized screws needed for the assembly. Since some components have varying stability requirements, a detailed overview would be very helpful, especially to prepare for or replace any missing parts. Additionally, I would like to know if the set uses special connection solutions beyond standard screws, for example cam locks, and if there are any particular details to keep in mind during assembly. Thank you in advance for your expertise!
Jamalli schrieb:
Are there comparable replacement parts that can be used without concerns, or can this quickly lead to problems?Replacing IKEA-specific connectors like cam locks is challenging because the thread, shape, and length are precisely matched to the fittings.
Using standard screws as replacements can reduce stability or damage the furniture. For chipboard screws, the rule is: if replacing, make sure to use the same length and thread type (chipboard screw with coarse thread).
Conclusion: For components with cam locks, it is better to get original parts; for simple screws, standard replacement screws of the same type can be used.
Jamalli schrieb:
I question that because some IKEA kits are quite restrictive when it comes to spare parts, which can already cause stability issues.I agree with that. Spare parts from IKEA are not always easy to get. Therefore, I recommend sorting the entire screw kit and checking all components for completeness before assembly.
If screws are lost, similar chipboard screws can be used as a temporary solution, but it is essential to use the same length and thread type. Cam locks: For this specific connection, replacements are generally not available, so it is better to contact IKEA directly or look specifically for them at a specialized supplier.
During the initial assembly, always be cautious and inspect every part to prevent errors from occurring.
To add to this: The Brimnes kit does not include screws with variable sizes but fixed types of screws:
- Cam locks
- Chipboard screws (mostly 16mm and 25mm (0.6 inches and 1 inch))
- Small metal screws for hinges
I often ordered replacement parts directly from IKEA, as other screws usually don’t fit properly. Important: The screw material and head design are precisely matched to the furniture design.
- Cam locks
