ᐅ Which screws are ideal for Malm furniture?
Created on: 23 Apr 2017 16:37
SON62
SON62
23 Apr 2017 16:37
Hello everyone, I am planning to assemble some IKEA Malm furniture myself and want to use the ideal screws for the job. Since Malm furniture is made of particleboard and assembled with fittings, I am wondering which types and sizes of screws are best suited to ensure stability and durability without damaging the material. I am especially interested in whether there are specific chipboard screws or wood screws with particular features that provide good grip for Malm furniture, and what to consider when choosing screws in terms of length, diameter, and thread. Does anyone have practical experience or recommendations on the best screws to use for assembling Malm furniture?
Garry
23 Apr 2017 18:12
For Malm furniture, I strongly recommend using particle board screws with fine threads. These are specifically designed for coated panel materials like MDF or chipboard.
SON62 schrieb:
whether there are special particle board screws or wood screws with certain properties that provide good grip for Malm
This is exactly the key point. The screw should not be too thick, ideally between 4 and 5 mm (0.16 and 0.20 inches) in diameter, and the length depends on which parts are being joined – usually, 30 to 40 mm (1.2 to 1.6 inches) is sufficient. It is also important that the screws are galvanized to prevent rust and to preserve the appearance of the furniture.
Additionally, I recommend screwing carefully to avoid splitting. Pre-drilling is not absolutely necessary for Malm, but it can be helpful in sensitive areas.
TARNE
24 Apr 2017 09:47
Wow, this topic is really interesting, I’m so glad you brought it up! 🙂
I recently assembled Malm sideboards myself and like to use chipboard screws with countersunk heads – this ensures everything sits flush and looks professional. Very important: the screws shouldn’t be too long, otherwise the veneer can crack! Ideally, 35 mm length and 4 mm thickness (about 1.4 inches and 0.16 inches).
Garry schrieb:
Chipboard screws with fine threads... between 4 and 5 mm diameter, and the length depends... 30 to 40 mm
I can definitely confirm this! 🙂 Also, always use stainless screws, especially if the furniture will be placed in more humid rooms. And folks, don’t hesitate to take a little extra care when screwing – it really pays off! :-)
SUPE2
24 Apr 2017 11:05
Chipboard screws measuring 4x40 mm (1.6x1.6 inches) are ideal for Malm. Stainless steel or galvanized. No pre-drilling needed, countersunk head is better. Done.
Kinbu
25 Apr 2017 08:59
Hello SON62, I’m happy to help you with a few more details. Malm furniture usually consists of coated particleboard or MDF. To maintain stability and avoid weakening the material unnecessarily, fine-thread chipboard screws are ideal. The fine thread grips well in the material and prevents stripping.
SON62 schrieb:
what to pay attention to when buying screws regarding length, diameter, and thread
It’s important to use a screw length that is at least 1.5 to 2 times the thickness of the material being joined. Malm often uses panels that are 16 to 19 mm (0.6 to 0.75 inches) thick, so screws between 30 and 40 mm (1.2 to 1.6 inches) are recommended.
If possible, use countersunk screws so the screw head sits flush with the surface. Zinc-coated screws protect against rust—especially important if you’re placing furniture in damp areas like the kitchen or bathroom.
If the material is particularly thin, pre-drilling slightly can help prevent splitting, but often the material holds well without pre-drilling. I hope this answers your question clearly! If you want to know more about types of screws or alternatives, feel free to ask.
