ᐅ Which screws are especially recommended for reinforcing modifications to Ikea BESTA units?
Created on: 27 Apr 2024 08:17
jadynmiHello everyone,
I am planning a reinforcement modification for my Ikea Besta shelving system to improve its load-bearing capacity. I have a question: which screws are particularly recommended for reinforcing Ikea BESTA?
I am looking for screws that not only provide high strength but also work well with the materials and construction of BESTA. Additionally, I am interested in dimensions, materials, and possible screw head types to make attaching the reinforcements as simple and secure as possible.
Does anyone have experience with specific screws or recommendations that are especially suitable for this purpose? Tips on which screws to avoid to prevent damage to the wood or joints are also welcome.
Thanks in advance for your opinions and advice!
Hello jadynmi,
The reinforcement modification for Ikea BESTA should mainly be done using screws that provide a good balance of load-bearing capacity and material compatibility. Recommended are mainly
- Wood screws made of stainless steel or galvanized steel with a countersunk head, approximately 4.5 to 5 mm (0.18 to 0.2 inches) in diameter
- Lengths between 40 and 60 mm (1.6 to 2.4 inches), depending on the reinforcement dimensions
These screws can generally be driven well into MDF or particleboard without placing too much stress on the material. It is important to pre-drill before screwing to avoid splitting.
Avoid using screws that are too long or too thick, as these could otherwise cause the panels to crack.
If you use metal brackets for reinforcement, suitable machine screws with washers are, of course, also advisable – these must fit the intended metal or plastic thread.
If you like, I can provide more detailed information on specific products.
I would like to add some more details and a brief guide to GiRoyce’s recommendations to help you optimize the reinforcement modification for BESTA:
1. Screw type: For the MDF and particleboard of the BESTA modules, countersunk screws are best because they can be recessed flush. Stainless steel or galvanized steel are ideal as they are rust-resistant.
2. Dimensions: I recommend a diameter of 4.5 mm to 5 mm and a length between 40-50 mm (1.6-2 inches), depending on the wall thickness and size of the reinforcement.
3. Pre-drilling: To prevent the material from splitting, always pre-drill with a drill bit about 1-2 mm (0.04-0.08 inches) smaller than the screw diameter.
4. Reinforcements: If you use brackets or wooden strips for reinforcement, make sure to fasten them with suitable screws. For metal brackets, screws like Spax screws with high holding power also work well.
5. Avoid: Avoid screws that are too thick, too long, or screws with round heads that do not sit flush.
In summary: countersunk screws, 4.5-5 mm (0.18-0.2 inches) diameter, 40-50 mm (1.6-2 inches) long, made of galvanized steel or stainless steel, with pre-drilling.
If you want, I can also provide typical sources or recommend specific brands.
GiRoyce schrieb:
These screws usually drive well into MDF or particleboard without putting too much stress on the material.I basically agree, but when choosing screws, you should consider not only the head type and material but also the thread profile. MDF and particleboard tend to tear out if the thread is too aggressive, especially if the screw needs to be removed multiple times.
Furthermore, it is worth considering whether reinforcements beyond screws are advisable – for example, using battens or additional metal brackets to distribute the load differently.
Jensson schrieb:
Avoid screws that are too thick, too long, or screws with rounded heads that do not sit flush.I would like to add that screws with countersunk pan heads are recommended because they provide more bearing surface when tightened, which improves pressure distribution and protects the material.
Question to everyone: Have you had any experience with specific thread types (e.g., full thread vs. partial thread) for BESTA reinforcement?
theo63 schrieb:
Have you had any experience with specific types of threads (e.g., full-thread vs. partial-thread) for BESTA reinforcement?Definitely partial-thread. This is because partial-thread creates less friction in the wood, allowing the screw to grip more securely and reducing the risk of the material splitting.
