I recently assembled an Ikea Platsa shelving unit and I’m a bit unsure about which screws are the most durable for this type of furniture. Since PLATSA is based on modular components and often uses relatively thin particle board, I’m wondering if the supplied screws will hold up in the long term or if there are better alternatives. I’m especially interested in whether stainless steel screws or galvanized screws withstand stress from moisture, weight, and frequent moving better. The quality of the threading and the material also matter to me, as I don’t want to have to reinforce the shelving later and would like to be satisfied with it over time. Does anyone have experience with particularly robust screws for Ikea PLATSA, or can recommend screw types that have proven reliable?
For PLATSA, I generally recommend using galvanized chipboard screws with fine threads. They are durable enough and grip the material well. Stainless steel screws are more corrosion-resistant but often unnecessarily expensive. It is important to choose screws that match the thickness of the board.
This is a very relevant question, especially since PLATSA systems, due to their modular design and the use of chipboard, are subjected to particular mechanical stresses. To ensure the longevity of the screws, we need to consider several factors: material, thread profile, and surface treatment.
First, regarding the material: galvanized steel is the standard recommendation as it provides good corrosion protection, especially indoors. Stainless steel screws significantly increase corrosion resistance—particularly when moisture may be present in the room. Their hardness and strength are usually higher, which helps prevent material fatigue.
The thread type also plays an important role. Fine threads ensure a secure hold, prevent the chipboard from tearing out, and distribute forces more evenly. However, the screw size must be precisely matched to the thickness of the boards.
I also recommend using screws with a countersunk head so that they can be recessed flush with the holes. This avoids the formation of stress cracks in the wood.
If you want lasting stability, switching to stainless steel screws is the best option—even though the cost is higher. Alternatively, you can use higher-quality galvanized screws with fine threads. Be sure to pay attention to the length: it should be about 1.5 to 2 times the thickness of the board.
Can you provide more details about the specific application? Will the shelving be subjected to heavy loads or frequent movement?
glamo schrieb:
If you want lasting stability, switching to stainless steel screws would be the best option – even though they are more expensive.Thank you for the detailed advice! Yes, the shelf will sometimes be loaded heavier (up to 25 kg (55 lbs) per module) and will also be moved occasionally, so durability and resistance to twisting are important. Do you think it’s better to use fully threaded screws or partially threaded screws for this? I’m also interested in the differences between the head types – flat head, countersunk, round head – for this application?
edisondan21 Jun 2021 13:52From a technical standpoint, I consciously recommend using countersunk screws with partial threading for PLATSA furniture. Partial threading provides better hold because the unthreaded section pulls the wood together instead of loosening it. The countersunk head fits well, as the screw head is flush or slightly recessed, preventing stress concentrations on the surface.
Regarding materials: stainless steel screws of grade A2 meet all requirements for corrosion resistance, strength, and durability, especially when the furniture component is placed in more humid environments.
I also recommend paying attention to screws with a slightly larger diameter when replacing, to avoid splitting the chipboard. Alternatively, pre-drilling can be done before inserting screws without pre-drilled holes. When using chipboard screws, only high-quality branded products should be used, as lower-quality screws are more likely to break or strip the threads.
edisondan schrieb:
I also recommend using screws with a slightly larger diameter when replacing them to avoid splitting the chipboard.Great tip! I fitted my PLATSA shelf with stainless steel screws and can confirm that after almost two years, there are no signs of corrosion. And yes, a little trick: when screwing, just be careful not to overtighten – a bit of patience and a gentle touch really help prevent damage to the wood.
Also, using the right size screws does add a bit more stability. And if you countersink the screws properly, the whole thing even looks neat. Give stainless steel a try; it keeps the fun of furniture building going much longer!
