ᐅ Which screws are best to use for assembling Ikea Besta units?
Created on: 1 May 2024 08:42
ixloteoHello everyone,
I am currently planning the installation of my new Ikea Besta cabinet and am considering which screws would be best to use to ensure a stable and durable construction.
The original assembly instructions do specify certain screws, but I wonder if there might be better alternatives—such as in terms of material, length, or thread type—especially if the furniture might be moved occasionally or installed in areas subject to higher stress.
Maybe someone here has experience with particularly recommended screws to use instead? What types of screws have you used for assembling Besta furniture and why?
Looking forward to your tips and recommendations!
Hey ixloteo! It’s great that you’re putting so much thought into this! 😊 For Besta, I usually use the original Spax screws because they provide excellent support and are quite durable. However, I have also switched to stainless steel screws myself since they don’t rust and are very long-lasting! Especially if you plan to move the furniture frequently or have it in more humid rooms, this can be a big advantage. So: don’t be afraid, trying it out is better than just thinking about it! 👍
Hello ixloteo,
Your question is very relevant because the choice of screws significantly affects the stability of a piece of furniture. The Besta system usually uses connector screws, often referred to as Euro screws or cam connectors. These provide a form-fit connection but are not designed to carry the full load like conventional screws.
If you rely on screws, you should pay attention to the following:
- Material: Stainless steel is ideal to prevent corrosion.
- Length: Screws should be chosen to penetrate at least 2.5 to 3 cm (1 to 1.2 inches) into the adjoining wood without coming through the other side.
- Thread type: For particleboard, as commonly used by Ikea, screws with coarse threads are better because they anchor more securely in the wood.
An alternative option is confirmat screws, which were specifically developed for particleboard furniture. They are stronger and provide excellent holding power.
I would also be interested to know what exactly you mean by “assembly” – whether you plan classic self-assembly, a permanent fixation, or perhaps a modular design that can be quickly adjusted?
Palenar schrieb:
I’m curious about what exactly you mean by “assembly” – whether you’re planning the typical self-assembly, a permanent fixation, or perhaps a modular construction that can be quickly reconfigured?Thanks for asking! I want to assemble the Besta shelving unit in the classic way, as intended by Ikea, but unfortunately, from past experience with furniture, screws tend to loosen when panels are connected or rearranged. Therefore, I’m looking for screws that are durable, do not deform, and hold the wooden parts firmly together – preferably something that can withstand multiple disassemblies.
So, more of a sturdy solution rather than a quick or temporary one. I hope this clarifies my situation a bit more!
Hello ixloteo,
since you are looking for a sturdy and reusable fastening method, I would like to share some explanations and tips:
1. Screw type: For Ikea furniture, regular particleboard screws are usually sufficient. Confirmat screws or cam connectors are more robust; however, the latter are not primarily designed to prevent loosening.
2. Material: Stainless steel screws are recommended because they are corrosion-resistant and protect the material in the long term.
3. Torque consideration: Screws may also loosen if too much or too little force is applied during tightening. A torque wrench or at least a good sense of the correct amount of tightness helps.
4. Optional thread locking: Use small amounts of wood glue on the thread tip or a medium-strength threadlocker (such as the "blue" type) to prevent loosening without fully bonding the screw.
5. For multiple assemblies, it is also advisable to fill the holes with wood shavings and glue if they become too loose over time.
Conclusion: Stainless steel particleboard screws with a diameter of 4-5 mm (0.16-0.20 inches) and approximately 40 mm (1.6 inches) in length work well. Certain handling tricks improve stability.
Jensson schrieb:
Conclusion: Stainless steel chipboard screws, 4-5 mm diameter and about 40 mm (1.5 inches) length work well.Exactly, that sums it up well! 😊 I would add that it’s best to get a few different types of screws at the start and test which ones feel best in terms of tightening and holding power. Don’t hesitate to use a bit of care when assembling, as that will keep the part stable and prevent it from loosening!
