ᐅ Which screws are best suited for IKEA Metod glass doors?
Created on: 31 Dec 2024 10:17
Gopenar
Gopenar
31 Dec 2024 10:17
I am planning to equip some IKEA Metod kitchen cabinets with glass doors and am now wondering which screws are best suited for this purpose. The door frames are quite delicate, so it is important to me that the screws not only hold securely but also do not cause any damage to the doors or surrounding materials.
Does anyone have experience with recommended screw lengths, materials, and thread types to ensure a secure fit while also allowing for easy installation and, if necessary, later adjustments? I am especially interested in whether it is better to use the original screws supplied with the IKEA Metod glass doors or to opt for specialized fasteners.
I look forward to your experiences and tips!
sanjon
31 Dec 2024 10:43
For IKEA Metod glass doors, I always use the original screws from IKEA. They are precisely matched to the material and offer a good combination of length and thread. Alternative stainless steel screws in size 3.5 x 12 to 15 mm (0.14 x 0.47 to 0.59 inches) also work well if you want something more robust.
Jensson
31 Dec 2024 12:05
Hi Gopenar,
here is a brief overview of how I handle this with Metod glass doors:
- Screw material: Stainless steel is best, as moisture is common in kitchens.
- Length: 12-15 mm (0.5–0.6 inches) is sufficient to secure the screw firmly without damaging the glass profile.
- Thread type: Fine thread, so the screw gently grips wood or metal without the risk of splitting.
For installation:
1. Use the included blind rivets or spacer washers if available.
2. Pre-drilling is important to avoid damaging the material.
3. Tighten the screws firmly but do not overtighten, to protect the glass and profiles.
If you don’t have the original screws, you can choose screws with an internal hex (Allen) drive, as they offer better control and protect the material.
Common mistakes are screws that are too long and press against the glass on the back, or coarse threads that damage the profile material. I hope this helps you.
lisku
31 Dec 2024 13:22
I usually use galvanized chipboard screws, 13 mm (0.5 inches) long, with a small head for Metod glass doors. It is important not to screw them in too deep, otherwise the frame may warp.
Elijah42
31 Dec 2024 14:48
Original screws from IKEA are usually already optimally matched. If you want to use alternatives, I recommend ones with a round head and a cross recess. This reduces the risk of damage to the door frame.
Kinbu
1 Jan 2025 09:11
Hello Gopenar,
I can understand how challenging it can be to find the right screws for glass doors, especially with a system like IKEA Metod, which is not very flexible. The combination of glass and thin aluminum profiles requires some caution.
Based on my experience, I recommend:
- Screws made of stainless steel for long-term corrosion resistance.
- A length of around 12mm (0.5 inches), as longer screws can deform the frame.
- Fine threads to avoid damage to the aluminum profile and the glass panel.
I have also had good results using spacers during installation, which help distribute the pressure points and reduce damage.
If you want a bit more flexibility, you can also consider special plastic screws with metal threads. These are rare but provide a gentler hold.
I always find it impressive how important careful, gradual tightening is. It’s better to tighten multiple times rather than applying too much force at once and risking damage to the glass panel.
I hope this helps you approach your project with more confidence. Feel free to share how it goes!
