ᐅ Which screws are best suited for the long-term use of Ikea Platsa?
Created on: 14 Jul 2021 10:37
Gidi55Hello everyone, I plan to use my Ikea Platsa system long-term and am considering replacing the screws because I’m concerned that the screws provided might not be designed for high long-term load. My question is: which screws are best suited for long-term use with Ikea Platsa? I'm interested in factors like material quality, corrosion resistance, and load capacity. Has anyone had experience with alternative screws that hold better or make the assembly more stable? Thanks in advance for your tips!
Gidi55 schrieb:
Which screws are best suited for the long-term use of Ikea Platsa?Interesting question, and one that is rarely asked. Most people just use the screws that come with Ikea furniture without giving it much thought. But that’s exactly the issue. The original screws are usually zinc-plated and designed more for short-term use. If you are aiming for durability, stainless steel or at least higher-grade zinc-coated screws should be used. This is especially important if the furniture will be subjected to higher loads or placed in a more humid environment, where rust-resistant screws clearly have an advantage.
However, I’m also cautious about simply upgrading the screws on your own – sometimes the dimensions and thread types of alternative screws don’t match perfectly, which can cause problems. A perfect fit is just as important as the screw material in this case. Since the Platsa system is modular, the screw material isn’t the only factor to consider – proper tightening and installation also play a crucial role.
To answer the question accurately, it’s important to know the exact application and the environment. I assume you are referring to the typical wooden components of Ikea Platsa, which are particleboard with a melamine coating. Self-tapping screws with wood threads are common here, usually 4 mm (0.16 inches) in diameter and 30–40 mm (1.2–1.6 inches) long.
For long-term use, I recommend:
- Stainless steel A2 screws, as they are corrosion-resistant.
- Screws with a full thread to ensure better grip and prevent the connection from loosening.
- A Torx drive, because it makes screwing easier and reduces damage to the screw head.
Additionally: Pre-drilling is often not required, but it helps if the wood is very hard or thick. Be careful when tightening to avoid over-torquing, as particleboard can split.
If you want to invest more effort in the project, you can also use wooden dowels in addition – these greatly increase stability over time.
How exactly do you plan to use it? Will the Platsa furniture be moved, loaded, or stressed frequently?
Surela schrieb:
How exactly is your usage planned? Will the Platsa furniture be moved, loaded, or stressed frequently?Thank you for the detailed assessment. The furniture is mainly intended to serve as storage in a relatively dry living room. It will be loaded with clothing, boxes of documents, and a fair amount of weight from electronic devices on top. Relocating the furniture is planned to be rare. There is a latent concern that the joints might loosen over time or the screws could rust. That is why I am considering whether stainless steel would be advisable from the start.
I can really understand that; these kinds of considerations show that quality truly matters to you. I had a similar experience with my Ikea system: after a few years, the original screws actually became loose, so I switched to stainless steel M4 Torx screws. Since then, everything has held better, and I feel more at ease. The important thing is not to just use any screws, but to make sure the dimensions match exactly. And once the system is set up and not frequently moved, rust-resistant screws are a better investment for peace of mind.
